Is the loud noise a squeaking or a rumbling sound? Also, does the dryer take a longer than usual to dry clothes? Are clothes still damp after the normal running time?
You can't post conmments that contain an email address.
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
That is the fuel pump doing its job of pumping. If it stops making noise, it stopped pumping, and no gas is getting into your motor. Your bike will not run without a running fuel pump. :)
if you have ice buildup then the fridge may be low on freon. or there is dust clogging around the pump or fan is not running. remove the bottom or back and look around the compressor. see that the fan is running.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
