SanDisk Sansa e260 MP3 Player Logo
Posted on Apr 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not turn on black screen with faint song that was playing on black screen frozen computer not recognizing when plugging in to USB it was lightly dropped
Joe Negus
Level 2:
President:
  • SanDisk Expert 652 Answers
  • Posted on Apr 21, 2009
Joe Negus
SanDisk Expert
Level 2:
President:
Answers
652
Questions
Helped
165677
Points
154
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
  • Joe Negus
    Joe Negus Apr 06, 2010
    This happened to me today Black screen Blue ring lit up and nothing
    Took the thing apart and pushed down on the chip set which is the rubber rectangle above the battery..Put the sansa back together and start... Sorry it took so long Rate me
5helpful
Creative zen became frozen
Let the battery completely drain, and after a while charge it using the charger available else thru computer without turning it on.. let it charge for 50% and then try switching it on. Try this if not get back to me.
4helpful
3answers
My Philips GoGear MP3 Player is stuck
Been using this for a few months. Froze up on same song while on vacation last month, and continued to play same song on repeat until battery went down. Now is frozen with "Do Not Disconnect" as it was being charged on my laptop. Attempted to unplug and plug back in and Windows gives DO NOT DISCONNECT!!!!!
I am having the exact same problem!!!!!
5helpful
3answers
ITouch screen frozen on USB and ITunes
ipod touch only reads apple's usb cord are you using apples usb cord
1helpful
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
2answers
There are no instructions in the instruction manual as to how I transfer songs to the MP3 player. Sorry, but I need MP3's' for Dummies. It's the JX-MP102. PLEASE HELP!
Just bought the JX-MP102 find it difficult to use but was able to download songs from a windows xp laptop - plug the mp3 player into the usb port and turn on just as you would for playing music its screen should light up and the computer will pop up a screen with several options click to start windows explorer and from there you can got to place holding music files and copy them the disk letter which represents  the MP3 player. On my machine my main files are on the C disk and a new D disk pops up for MP3 player. I also have a windows vista machine and it also recognizes the player as a new disk drive just like a flash drive.  Unfortunately I can the player to work for a few minutes at best right now even with the music files successfully loaded and playing so I may return it tomorrow. Hope you have better luck.
   rvwill1930
1helpful
2answers
there is a restart button on the bottom but it is a very small hole so maybe use a toothpick to push the button
3helpful
3answers
My mp3 player is frozen
Plug it in to the computer with the USB cable, use a paperclip to push the reset button inside the top hole, and then press the power button.
3answers
Did you figure it out? I have the same message on mine and nothing I do fixes it... my laptop won't even recognize the usb device so I can't look into reformatting the player.... if you figure it out let me know.
2answers
Player frozen
You should let the battery be flat and then charge it.
It'd then work. It happened to me twice. Hope this helps.
My computer doesnt recognize my sansa
their are over 11000 problems with this sansa 4GB player. IT is strongly recommended not to buy this ...My screen frozen, computer undection USB, songs deleted by itself, something error.and ETCCCCCCCC>.. latino, ur right, try reseetinn it , then unistall drive..might fix the problem..good luk ..
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
