Samsung YP-K3 MP3 Player Logo
A
Anonymous Posted on Sep 15, 2013
Driver download I have a Samsung YP-K3JAG/XSA and need to download the Software/Driver for it. My OS is Windows 8
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Jul 11, 2008
SOURCE: Samsung YP-K3 MP3 Player
Available from Samsung suppoort site along with firmware upgrade tool
Anonymous
  • Posted on Sep 12, 2008
SOURCE: samsung mp3 yp-u3j no driver
download windows media player 11
once you install it follow these steps:
-right click my computer-click properties-click on hardware tab- then click on device manager
- plug in your yp-u3jqby mp3 player
-you should see your mp3 player pop up. double click it. then upgrade drivers.
after endless hours... i finally got it to work. i guess the trick is windows media player 11.
Anonymous
  • Posted on Dec 21, 2008
SOURCE: Samsung YP-T9 Driver
Problem video
Anonymous
  • 3 Answers
  • Posted on Dec 28, 2008
SOURCE: Samsung yp-u3 driver
you need to go on the samsung website and go on troubleshooting problems and follow the step by step guide on that website. you can also download drivers on it too
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Mar 25, 2009
SOURCE: lost install disc for my samsung yp s3 on win me
You can go to Samsung's website and go to the Support section to get that software. Because of the way that Samsung designs their website, I cannot give you a direct link, because they require you to manually enter in your model # before you can go on.
I can not get my yp-t8 to download to my pc my pc is xp home and the driver that ihave is win 98
If the driver you mention is only for Win98, it is of no use in XP.
For the YP-T8 there are 3 model players, that might need different driver, software and firmware (under OS there's a listing for the supported Operating Systems).
Select your model on next page:
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP00&searchWord=ypt8&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=yp-t8
Next select the matching driver, software for your computer.
Download and install the driver and software.
Also look under firmware, to see if there are updates for the player.
1helpful
USB not connecting.
Well you need to install the driver/software of your player into computer, install them from the cd comes with your player. If you don't have the cd then please follow the below link to download the driver/software -
http://www.samsung.com/uk/consumer/tv-audio-video/mp3-digital-audio/yp-t10/YP-T10JAB/XEU/index.idx?pagetype=prd_detail&tab=support
(First connect your player to computer and then install the driver/software after downloading. If your computer ask to restart then restart them)
Good Luck!!
1helpful
26helpful
9answers
Samsung YP-U3 driver
REALLY REALLY REALLY REALLY WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! yes yes yes yes!!!!!!!!
I solved the problem after i was really crazy of anger with samsung company, but i found this solution in one forum.Thank you
very much, anonymous Guest!!!!!
Hi All,
I just solved the problem after many attempts!
It works for me, and i hope it works for you too~First install media player 10!
When I plug in my YP-U3 player, the computer says it needs to search for a driver, then i let it search it online. But it normally
won't search the driver on the internet. Then, it will give a prompt to ask if you want to find a solution or search the driver from
the PC. Choose the second option, searching from the PC. Then change the directory to C: (Which is the most crucial part).
After a while, the driver should be found and a warning message will appear. Forget about the warning, choose install the
hardware anyway, player should be recognized by then.
(I have had windows media player 11(10 also works), direct X 9...etc. before installing the driver)
4helpful
3answers
Apple Mac driver for Samsung YP-T10JAB/XSA
this device uses mtp protocol. Mtp protocol supported from all OS (mac, linux, win etc..) check these links:
http://en.wikipedia.org/wiki/Media_Transfer_Protocol
http://www.fixya.com/support/t429679-device_drivers_samsung_yp_t9jab_xac_mp3
11helpful
6answers
Samsung mp3 yp-u3j no driver
Seems that if you plug the device in and it cannot find a driver then you have to force the computer to look for one. Even installing the Samsung software didn't help and their website instructions doesn't tell you the name of the driver. I did the following which worked.
Right click on my computer, select properties and go for the hardware tab.Click device manager and look down the list. Somewhere you'll find a yellow warning icon next to Samsung y3 or unrecognisable device. Right click on this and go for properties then the driver tab then driver details You'll see there isn't one. Click OK and go for update driver. Click the Advanced install option and include the specific location C:\WINDOWS\system32\drivers. Click OK and the computer should tell you its found an MTP device. The driver it uses if C:\WINDOWS\system32\drivers\wpdusb.sys. This worked for me.
2helpful
4answers
58helpful
15answers
Samsung YP-K3 mp3 player requires driver but I have no cd!!
I've had this problem. Windows media player doesn't seem to find it, and I couldn't figure out which file I needed from the site. I have xp, but I'm assuming this might also work for vista. Go to Control Panel. Open System. Click the Hardware tab. Click the Device manager button. Find the yellow question mark labled Samsung YP-K3 and doubble click it. This should open a window that will let you (re)install the driver, which it will find for you after having you set up a few simple options. Hope this helps.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
