SOURCE: Kenmore dryer buzzes but does not run
You could have any one of several problems with that gas dryer -
Turn dryer on.
Go out to where dryer duct exits house.
Feel the amount and strength of air blast coming from vent.
Air blast should be strong and cover the full face of the vent.
If not, check that dryer hose is not crushed/collapsed behind dryer as it is pushed back into position.
Clear any restrictions in the vent pipe.
Clean lint screen.
Check that there is no restriction where air is pumped into or discharges from the dryer drum on the inside.
If you are able to, check to see if you can see the pilot ignitor lighting.
Reply back your findings for further instruction or information.
SOURCE: Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
SOURCE: My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
