I have a F05 fault code on a Hoptoint AQxxf149. I have cleaned out the pump but where is the pressure switch that the hotpoint web site directs you to?
Can anyone help?
Geoff
Hi
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Hotpoint engineer visited a few weeks ago, seal had come away+ H20 error. Now having H20 and F-05 error wont finish seems to over fill and water leaking from somewhere below.
