Question about Franke Saphira Espresso & Coffee Maker
Franke saphira malfunction 8 help What is this?
    New Friend:
Malfunction 8 on the Saphira is a fault in the brewing head region. We have two of these machines, the first time I saw the malfunction 8 message it was a brewing head problem, fairly straightforward to change but I believe they are quite pricey. Worth a strip down and a wash out as they can bind with coffee grounds. The second occasion it turned out to be a problem with the motor that drives the brewing head. It is a fairly small dc motor with a worm drive plastic gear, it has a micro switch mounted on it to measure the movement of the brew head assembly. On this machine the gear had stripped, so the brew head wasn't being moved, and that generated the malfunction 8 code again. Fairly simple to change, but no idea on the price of the part, but unlikely to be cheap. Also it is unlikely that the gear itself can be changed as the motor is held in a plastic assembly which will almost certainly self destruct when opening it no matter how careful you are. Incidentally, both of these machines have done over 50,000 coffees, which is probably way more than they are designed for.
Posted on May 15, 2011
    New Friend:
We Had The Same Malfunction 8 Problem And It Came Down To A Swolen O-Ring In The Brewing Piston, We Replaced The O-Ring With One Slightly Smaller That Still Sealed The Compartment And Our Problem Was Solved, Hope This Helps Others.
Posted on Feb 19, 2010
  • xpresscoffee Aug 22, 2011
    Malfunction 8 is normally the brew unit, which can be one of the seals. In more serious cases it can then be the brew unit motors or something else relating to the brew unit.
    If you keep your machine serviced as the brew unit is the main part that is serviced/changed on the yearly service.
    Another way or prolonging your brew unit is to run the machine clean more frequently and not waiting for the coffee clean message. We find that proactive cleaning helps lubricant the brewer so it will last longer.
    XpressCoffeeuk.co.uk
  • 3 Answers
Malfunction 8 is a brewer fault NOT a motherboard issue. I believe that it is not usere fixable and you need to call a spanner man (or woman)
Posted on Nov 24, 2009
Malfunction 8 is mother board failed, you will have to take it to franke uk
Posted on Jul 08, 2009
SOURCE:
Comes up on the screen displaying 'malfunction 8', what to do from here?
It's the brewer unit issue.Does your unit make loud noise when you start the machine if it does then it's drive motor fault mostly it's one of the screw that holds the motor may be broken.
Sep 04, 2013 | Franke Saphira Espresso & Coffee Maker
Franke flair malfunction 8
you have problems with the brewing group. perhaps the o-ring on the upper piston is broken.
Dec 05, 2012 | Franke Saphira Espresso & Coffee Maker
I have a malfunction 8 that shows up
malfunction 8 is the brewer piston oring. one from a franke saphira will work.
Aug 26, 2011 | Jura Capresso Impressa F9 Espresso Machine
Need a parts brake down diagram for a franke saphira coffee machine!!!
The Franke Saphira is the same machine as the Jura X7.
Here is an interactive diagram.
Mar 04, 2011 | Franke Saphira Espresso & Coffee Maker
Can I use Jura cleaning tablets on franke saphira?
hi , you can use the cleaning tablets as jura and franke have the same brewing unit,
Sep 16, 2010 | Franke Saphira Espresso & Coffee Maker
Hi. Malfunction 4 on Franke Saphire coffie machine, What should i do ?
The temp sensor on the Steam block has failed, a replacement is required
Aug 06, 2010 | Franke Saphira Espresso & Coffee Maker
Malfunction 8 On Screen
Likely cause of this is a blocked worm drive. The worm drive takes the coffee in and then, after brewing, ejects the used grounds into the Dump box. Over time, coffee grounds accumulate on the worm drive and eventually jam it. This is Malfunction 8. Machine will need to be stripped and cleaned. Hope this helps.
Feb 16, 2010 | Franke Saphira Espresso & Coffee Maker
Malfunction 8, intermittent Sometimes the brewer seems to be straining, then up comes the malfunction 8 message. I think the brewer needs a good clean and lubricating, possibly the seals are in need of...
You're right about the straining bit. It's a jammed worm drive. Usually Malfunction 8 is preceeded by painful noises and sometimes even though the machine sounds like it's brewing, all the coffee ends up in the drip tray instead of the cup! The machine will need stripping, the worm drive cleaned off and lubricated and then reassembled. It's about an hour's job. Hope this helps.
Feb 13, 2010 | Franke Saphira Espresso & Coffee Maker
Franke safira reads Malfunction 4
error/malfunction 4 usually means thermistor/sensor on steam generator block has failed ie open circuit /disconnected......................small metal encapsulated device clipped or screwed to block,2 wires to harness plug...
Feb 24, 2009 | Franke Saphira Espresso & Coffee Maker
Franke Saphira Espresso & Coffee Maker Logo
3,303 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
jonathan Hanson
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
