RIM BlackBerry Bold Smartphone Logo
Posted on Apr 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I receive a call my blackberry pearl8100 screen went white first
Then become black since that time screen is black i , it didnt fell or got hit any where. could u tell me please if its a hardware problem or software problem
Steve Brown
Level 3:
President:
  • RIM Master 688 Answers
  • Posted on Jun 05, 2009
Steve Brown
RIM Master
Level 3:
President:
Answers
688
Questions
Helped
393882
Points
2264
Take the battery out and put it back in and see if your phone reboots ok.
My iphone has got a black screen
Have you attempted to perform a hard reset yet?
So do one thing...
First connect to ur PC with ITUNES.. this is done by holding BOTH the home and sleep/wake buttons down until you see the white apple symbol onscreen.. then release both buttons... this typically resolves this issue you're describing...
If not... it sounds like you should perform a full restore via iTunes... hopefully you have a recent back up saved that you can restore from...
if that also doens't work, then 99% you have a hardware issue need to go for repair....
Apr 05, 2014 • Cell Phones
My battary went dead on my black berry curve, i try to charge it , im getting a white screen that say "app error 523 reset , i try to reset it and nothing is happens, i also took d battary out and...
Cynthia, When the battery goes very low and we keep trying to use the phone by restarting it, the firmware get corrupted. And for a corrupted firmware, the only way out is to get it reinstalled. So, please do that as the firmware of the phone has got corrupted.
The screen whites out n only way to get it back is take battery out n let it start back up
Hi there
Whenever your screen goes white again just hit the ALT+RIGHT SHIFT+DEL your blackberry will reset itself. It will go black for about 2 to 4 seconds then you will see the famous blackberry hourglass. Be patient and in about 2 to 5 minutes your blackberry will reset.
Try freeing up some space on your blackberry by deleting some unecessary files and do not run too many applications at once.
I had 2 blackberry 9700 s. One has a broken screen, the other has a bad speaker receiver. I took the screen from the blackberry that had a good screen and placed it in the blackberry with the good speaker...
The white screen is a ribbon cable issue.
You have had both phones apart so you know what I am talking about when I say ribbon cable?
It's the flexi cable that links the screen to the main body of the phone.
CHeck it is not damaged and check it is connected correctly.
You will see lots of people with all makes and models of mobile phones have this same issue and 80-90% are caused by a pesky flexible cable.
You may find a replacement fairly cheaply on Ebay if you have damaged both cables. They are delicate so take care when handling.
Nokia N95 8Gb fell,screen is white.
The screen cable may have become loose or dislodged. You can find out how to replace the screen and also to check the cable here - http://spyda.vox.comlibraryphoto6a00d09e7ac027be2b00d41442e37f685e.html.
You can pick screens up on ebay too.
1helpful
2answers
Blackberry pearl wont go past the white screen with the hour glas
the only thing that you can do with this issue is try wiping the software clean and reinstalling fresh software. You would need the blackberry desktop manager first installed on your home computer. If you dont have the cd the program is more then likely available on your mobile providers website. Once the program is downloaded and installed follow these directions
To perform this procedure, follow the steps below:
  1. Remove the battery from the BlackBerry device.
  2. Double-click Application Loader in BlackBerry Desktop Manager while the BlackBerry device is not connected to the computer.
  3. Click Next on the Welcome to the Application Loader Wizard screen.
  4. When the Communication Port Selection screen appears, connect the BlackBerry device.
  5. When the USB-PIN option appears, click Next. The Device Application Selection screen should appear.
  6. Re-insert the battery and allow the process to complete.
Blackberry pearl8100
You can find Video Disassembly Instructions at
www.fonlogix.us
They have New LCD's and Lenses for the cheapest price.
Here is a Coupon code for 10% off at their site
Code: Fixya10
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
