If you are experiencing a "Paper End" error on your ECR 7700 cash register, it typically indicates that the paper roll has run out or is not properly loaded. To resolve this issue, follow these steps:
Replace the paper roll: Open the paper roll compartment of your cash register and check if the existing paper roll has run out. If it has, replace it with a new roll of thermal paper. Make sure the paper roll is the correct size and fits securely in the compartment.
Load the paper correctly: Ensure that the paper roll is properly loaded into the cash register. Follow the instructions provided in the user manual or any diagrams on the cash register itself to ensure correct alignment and positioning of the paper roll. Make sure the paper feeds through the appropriate paper slot or path as indicated.
Reset the cash register: After loading the paper roll, close the paper roll compartment securely. Some cash registers may require a reset to clear the error message. Refer to the user manual or specific instructions for your ECR 7700 model to perform a reset. This may involve pressing specific buttons or using a reset function on the cash register.
Test the cash register: Once the paper roll is replaced and the reset is performed, test the cash register by attempting a transaction or printing a test receipt. The "Paper End" error should no longer appear, and the cash register should function properly.
If your Olivetti ECR 400.EV is frozen and not responding, you can try the following troubleshooting steps:
Reset the cash register: Turn off the power switch located at the back of the cash register, unplug it from the power outlet, and wait for 10-15 seconds. Then, plug it back in and turn on the power switch.
Check the connection: Ensure that the power cable is securely connected to the power outlet and the cash register. If the connection is loose, it can cause the cash register to freeze.
Clear any paper jams: A paper jam can also cause the cash register to freeze. Check if there is any paper stuck in the printer or any other part of the machine.
Contact Olivetti support: If the above steps do not work, it's best to contact Olivetti customer support for further assistance. You can find their contact details on their website or in the user manual that came with the cash register.
Note: Before attempting any of the above steps, make sure to backup any important data in the cash register.
factory reset ... or enter BIOS of the machine (I don't know what to press for that model when you start boot computer , usually the key is DEL) and set up !
Question is how to connect PC with Casio SE-C6000 Cash Register. Answer is very easy and simple. This ECR is POS system and has capability of FTP . Download any FTP software from net. Go to ECR program 3 . Press 798 and sub Total Key. enter local network area unique IP address for this ECR starting with 192.168.1.10 as( 192168001010) an example and must be not conflicting and within the range of local area IP Adresses. then press CA/Amt. Key. then 255255255000 for sub mask and press CA/Amt Key again..Then 192168001254 as gate way then press CA/amt Key again and sub Total Key to finalize. Connect PC with network cable in RJ45 slot on ECR. Turn the mode key on Reg Mode for normal operation. Now on FTP software which is already installed on your PC open and put host ID IP address of your ECR. User Name is "SCTHRD" and Password is : "OTTFFSSENT" then Enter . You will see all program of ECR in folders. I hope it will help your need . Ibrahim Azhar
There is an ECR350 manual here that might help:
All of these manuals can be downloaded at: http://the-checkout-tech.com/
olivetti CMS-140B User Programming
olivetti ECR-2100 User
olivetti ECR-2150 User
olivetti ECR-2200 User
olivetti ECR-2250 User
olivetti ECR-2300 User Programming
olivetti ECR-2350 User Programming
olivetti ECR-2400 User Programming
olivetti ECR-2450 User Programming
olivetti ECR-2500 User Programming
olivetti ECR-2550 User Programming
olivetti ECR-300 User Programming
olivetti ECR-350 User Programming
olivetti ECR-3550T
olivetti ECR-5000 User Programming
olivetti ECR-5100 User Programming
olivetti ECR-5700 User Programming
olivetti ECR-5800 User Programming
olivetti ECR-5900 User Programming
olivetti ECR-5920F User Programming
olivetti ECR-6100 User Programming
olivetti ECR-6700 User Programming
olivetti ECR-6800 User Programming
olivetti ECR-6900 User Programming
olivetti ECR-6920F User Programming
