Hotpoint JE740WY/GY Microwave Oven Logo
Posted on Apr 16, 2009
Set power level on hotpoint microwave
I can not set the power level. It stays on low. Can not find manual
Samsung Microwave power level - no button
As you didn't specify any specific model, one of the Samsung models uses this scheme to change power levels.
You begin by pressing the "Microwave" button once. Pressing it again will display different power levels, from low to high.
How do i change the power setting on a Sharp carousel microwave
Which model of Sharp microwave do you have?
For the SMC1441CB, after setting the cook time, press the power level button and then the appropriate digits for the percentage of full power to use. For full power, press power level then 1 and then 0. For 50% power, press power level then press 5.
For the SMC0710BB, after setting the cook time, press the Power button until you see the desired power level displayed on the LCD screen. Press Power once to get 100% power. Press Power 6 times to get 50% power.
For the R-659YW, you set the power before setting the cooking time. You press the Power button several times to get to the desired power level. Pressing Power 7 times will have the microwave cook with 40% of its full power level.
Many current Sharp appliance manuals are available on their product page or the Sharp support page. The current Sharp microwaves are listed here: http://www.sharpusa.com/ForHome/HomeAppliances/Microwaves/Models.aspx?facet:configurationfilter=Countertop . Other appliance manuals are available when you enter the model number in the search bar at http://www.sharpusa.com/Support.aspx .
I hope this helps.
Power it stays at 100% want 50%
Place the items inside the unit and close the door. Set the cook time, then press the "Power Level" button. When the display asks for input, press "5" for 50% power. Then press START.
What is the output power of National NN-C2000P microwave oven?
the pwr rating is normally on the label.
google for a manual
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
HI I HAVE A LG MICROWAVE OVEN MODEL# LMVM 2277ST ;1100W IT WORK BUT SLOW IT TAKES TIME TO WARM THE FOOD
I see by looking at the owner's manual there is an option to set power level from 0% to 100%, maybe that is set too low (see page 14 of manual). If don't have manual for that model (LMVM2277ST), can get from this web page (look near bottom of page and click words "owner's manual" that are underlined) :
http://www.ajmadison.com/cgi-bin/ajmadison/LMVM2277ST.html
1helpful
How do I adjust the power levelthen start the
Press "Power" until you get to the level you want. Then enter the # of minutes on the keypad (CANNOT use express cook times.) An alternating runnig hum will let you know the setting is working.
Hotpoint microwave MWH121 has 5 power settings but the manual does not indicate the power of each level.
With only 5 steps between zero and 100 percent, I'd say it's graduated in about 20% intervals.
Maybe 20, 40, 60, 80 & 100% or 0 (timer) 20, 40, 60 & 80%.
100% is the default setting unless something else is selected.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If you don't have your owner's manual, you can download it free from GE/Hotpoint.
Please reply back if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Hotpoint RVM1425
The first thing I would suggest is to turn off the breaker or unplug it from the wall for a few minutes to "reset" it, then try again. If a reset doesn't fix it, I would think you may have a defective magnetron. When you heat something of very low moisture content, it can lead to microwave energy not being fully absorbed, but instead being reflected back to the magnetron. This can damage it. This is usually best left to a pro to repair. In case it might help, your owner's manual can be found online at: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=RVM1425BA
Top Hotpoint Microwave Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
