Did you forget to shut off the fuel before moving your pressure washer? It sounds like the engine is flooded. Honda GX engines are famous for flooding with the fuel valve left on when moving. Or did you store it in a tilted position? Take the spark plug back out and pull the pull rope a few times...you should see the gas that flooded ejected from the plug hole. Once you feel you got all the gas out, replace the plug. You may want to check your oil and make sure it isn't full of gas now also. If it is good, or you have changed your oil then start it up....It should not have the resistance anymore and should start just fine. Good luck
SOURCE: Karcher 2400R
You have a poor signal to the spark plug usually caused by a rusty fly wheel found underneath the pullcord casing. clean it with releasing ajent such as wd 40. common when not in use for a while.
SOURCE: Katcher pressure washer w/ 5hp Honda Engine
pour a bottle of carburettor or fuel injector cleaner in the fuel tank, replace the spark plug and set the spark pluglug gap at 0.7mm. Replace the air filter element. Also change engine oil if necessary (mobil 10w30 synthetic.
SOURCE: honda pressure washer cuts out when lance trigger released.
You most likely need to set your valve clearances. If it is hard to
pull over or the recoil snaps back after starting your valves need to
be set for sure. This may not be the entire problem but it is a good
start. Also change the spark plug, a bad plug will cause odd problems
and is too cheap not to eliminate as a source. In addition check your
fuel, pour a little out into a white container (I like spray paint can
caps for this) and look at the color. If it is yellow to orange it is
bad. You can pour it into you car, the car electronic sensors will
compinsate for it quality but a small engine can't. Use a NGK BP6ES or
BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove
the spark plug and the valve cover. Pull the recoil over slowly until
the intake valve opens (intake is closes to the carb and it will go
down when it opens). Now put your long screwdrive down the spark plug
hole. Slow pull the engine over until the screwdriver handle is at it
highest point, this is top dead center. It may take a few attempts. Now
check your valve clearance between the rockers and the top of the
valve. The intake should be .006 and the exhaust .008, both can be +/-
.001. To adjust: hold the large nut with the 14mm then loosen the small
one with the 10mm. Lefty loosey. Now turn your large nut until you get
the correct setting and then tighten the small one the lock it in. It
may take a few attempts and alway reverify your setting after you lock
it down. Once done, find top dead center again and reverify. Now your
valves are set.
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
SOURCE: pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
FOUND THE PROBLEM ON MY HONDA 160 MOTOR EXAUST VALVE IS STUCK HOW CAN I UN STICK IT
