Question about Frigidaire Affinity ATF7000ES Front Load Washer
Frigidaire Affinity dryer error code?
Hi, I just bought a Frigidaire Affinity dryer (the 6000 series), and heard an odd sound. I went to check, and rather than the minutes showing on the screen, it looked like "A0" or "AD"? The bin was still spinning. Any ideas?
  • 4 more comments
  • Terry Todd
    Terry Todd Nov 15, 2007
    I have the same problem.. AD and error lights flashing... It should not be AutoDry becasue the samll amount of towels in dryer are still very Damp..
  • Anonymous Aug 30, 2008
    my dryer began to dry and then stop. On the displey it appears E68
  • Anonymous Sep 07, 2008
    I have the Fridgidaire Affinity and after about 2 minutes it stops drying and gives me the error code AD but I am not sure what this code means.
  • thehouse Nov 03, 2008
    I have the same problem. I put wet clothes in the dryer and turn it on. About 30 seconds later it shuts off and beeps with a E68 on the display with the clothes still wet. This is such an annoyance. Can anyone help?
  • jstwaytooswe Apr 20, 2009
    I have an affinity model AEQ7000EG0 dryer. It was working fine and then the light inside the dryer blew. It allowed me to put a load in and dry and everything was fine. Now I have gone and tried to start the dryer and I get a dr error message on the read out screen. Does anyone know what that means? Also where can I get a owners manual or service manual? Thannk you for you help
  • Joyce Howse
    Joyce Howse Jul 14, 2014
    My dryer shuts off and beeps what can I do to fix this problem
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Posted on Sep 26, 2009
According to the Frigidaire wiring diagram and codes list E68 means one of the keys ist stuck.You can enter function test mode and check which button is at fault. http://www.frigidaire.com/product.aspx?productid=1787
Posted on Jun 08, 2009
It means auto dry it will check the temp of the clothes so if they dryer quicker then 45 minutes it will shut off earlier instead of running the full 45 minutes.
Posted on Oct 08, 2007
My dryer is flashing a code (dr)
what does this mean
Posted on Aug 19, 2012
MY Frigidaire Affinity Gas Dryer is giving me a code of E68, which is a button is stuck. But how do I unstuck it? I tried to wiggle it to free it, stick a screw driver between the button and the front case to free it. None of these things work. Is there a way to open the machine to fix the stuck button?
Posted on Sep 14, 2011
My dryer is displaying E68
Posted on Jun 14, 2009
In the manual it says AD is the adjusting time according to moisture level for those who keep drying but display this it is normal for those who display and seize to dry is not normal and the E68 code says that there is a button jammed on your system either one is not functioning properly or it is wedged hope this was helpfull to all
Posted on Feb 07, 2009
    New Friend:
My frigidaire dryer is showing E 64 error code, Help.
Posted on Mar 05, 2013
  • Bobby Vanatta Jan 19, 2014
    same code here, did anyone ever figure it out?
    New Friend:
My dryer I diplaying E66 door open ive replaced the door sensor
Posted on Dec 04, 2013
My dryer shut off before the cycle ends with a code Ad and is not dry.. What should I do? Anybody knows why?
Posted on Jun 13, 2011
E68. CLEAN THE LINT FILTER AND BASKET. UNPLUG UNIT. REMOVE 2 SCREWS INSIDE DRYER HOLDING BASKET. PARTIIALY REMOVE AS THE BASKET IS ATTACHED WITH TWO WIRES GOING TO A SENSOR. THESE WIRES ON MY UNIT WERE CAKED WITH LINT AS WAS THE REST OF THE UNDERSIDE OF BASKET. CLEAN WITH HAND OR VACUUM OR BLOW AND REASSMBLE. WORKED GREAT FOR ME.
Posted on Jun 30, 2011
  • catsatterwhi
    catsatterwhi Aug 07, 2012
    Man! I did that and it still stops after 30 sec! With the E68!
  • catsatterwhi
When you select cycle
Posted on Apr 21, 2014
*E68* UNPLUG FIRST. Then I took off my lint filter and the basket and cleaned the wires going to the sensors. Now my dryer is working great. I used ROYZTOY65 SOLUTION THANKS ROYZTOY65
Posted on Aug 04, 2012
  • teribilbe
    teribilbe Mar 05, 2013
    E68 error. I called out a repairman and it was going to cost me over $600 to get repaired. It was the MOTHER BOARD that went bad. So I went to my local Aaron's and rent to own a new washer & dryer.
I have a Dryer that was reading "AD" and I realised that I was working on the dryer area earlier that day and shut the gas off... So I might say that the "AD" is because there is not gas going to the dryer...
Posted on Nov 10, 2008
On my gallery series dryer AD means I can Add clothes now. Hope that helps
Posted on Sep 26, 2007
I have an affinity dryer that has dn displaying on the in the digital read out what does this mean
Posted on Aug 29, 2008
SOURCE:
Error E52 on frigidaire affinity
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
Aug 06, 2014 | Frigidaire Affinity Series FASE7073LA...
Clear codes for affinity dryer
Hi Friend, this is Z. I am happy to assist you!
I see that you have a Frigidaire Affinity dryer and I'm presuming you are seeking information on how to clear error codes on your dryer. May I please have your model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can help pinpoint the exact problem. In the meantime, you can reset your dryer by either unplugging your dryer or flipping off the breaker for roughly ten minutes. This often clears most false error codes. Hope this helps!
May 21, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
Apr 25, 2014 | Frigidaire Dryers
Error codes for a frigidaire gallery series model gleq2152es0
Check out this affinity manual for error codes on electrolux dryers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2012 | Frigidaire Dryers
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
you have a problem with the heat you can't just say it's the element or thermistor you have to unplug it,take it apart and get in there with a meter and check all the t-stats,element thermistor,if they check good you could have a bad computer board but hopefully it will be the element but if you just bought it the dryer is still under warranty for the first year so either call whoever you bought it from or the 800 number off of the machine
Jan 02, 2018 | Frigidaire Dryers
Washing Machines Logo
16,300 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
