I have a front loading whirlpool dryer. I occassionally have a 1 inch long brown streak left on clothes. It almost seems like a burn mark. It is always a perfectly straight narrow line. What is causing this?
Not having seen this before, but my best guess would be that the piece of clothes is caught in one position and rubbing on the gasket material around the rear of the drum. Is the mark permanent?
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
more than likly it is coming from the dryer. get a paper towel or a towel and run it between the inside of the drum and the front where they come together. stick it through the slot and run around the drum. do the front then do the back see if you see the same streaks. and let me know thanks
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
the brown streaks and holes will be when they get stuck the dryer is still turning and it will be friction marks if it is getting stuck between the inner and outer drums than check to see if there is any wobble in the inner drum by opening the door and placing your hand at the top of the outer rim of the panel and place your fingers to the top of the inner drum pull your fingers towards your hand if there is any movement than the bearings are gone which will need replacing once done then this will eliminate the problem if there is no movement check to see if there is a seal missing from between the inner and outer drum u can find this out by checking with your fingers than calling the manufacturer to see if there is supposed to be one there
Check an earlier post of mine. This problem was killing me and Whirlpool was of no help at all. They claimed to never have heard of these thin brown streaks. Well, it was the dryer and as proof, I found where the thin brown lines were coming from. The felt had worn out in one spot allowing thin, whites and other thin items to slide in between the drum and the backing, resulting in the transfer of a thin brown line randomly on my clothes. Replace the felt (rollers and bearings if necessary) and with the drum apart, clean off the burnt brown streak of the backing with Simple Green. No more problems.
mich, The brown streaks are probably caused by worn drum guides and lower basket seal. I've seen this quite often on Frigidaire dryers. Part numbers 5303937139 upper felt guide and 5303283286 lower basket seal. This can be a task for an inexperienced person but can be done. It requires removing the top panel and front panel/door assy. The old guides have to be scraped off. The upper felt guides and lower seal glue on. Catriver...post back.
My clothes also get marks on them. I always thought it was from the washer. They are permanent marks. It has ruined all my clothes.
