Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
SOURCE: Oki C9500 Printing Problem
Check the LED Head and LED Connection. The LED heads are interchangeable, BLK, Cyan, Magenta, Yellow.
SOURCE: False empty toner reading
You may need to do a full reset.
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
The above is of course assuming no hardware/firmware fault on the printer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Oki C5500 printing a yellow stripe
1) clean LED heads with Alcohol swab.
2) Check fuser rollers for dirt, smudges. Clean with swab.
3) Remove all toners/drums and check for spilled toner. Vacuum or wipe clean.
4) Check tansfer belt for marks, stray toner, creases.
4) Re-seat toner and drum cartridges.
