Question about Lanier Ld 040 With Feed, Print, Scan, Stand - 35k Copies
How do I delete a contact from fax settings - Lanier Ld 040 With Feed, Print, Scan, Stand - 35k Copies
    Scholar:
  • 82 Answers
Deleting a Registered NameThis section describes how to delete a name.
  1. Press [System Settings].
  2. [Administrator Tools>.
  3. Press [Address Book Management].
  4. Press [Delete].
  5. Select the name you want to delete.
    Press the name key, or enter the registered number using the number keys.
  6. Press [OK].
  7. Press [Exit].
  8. Press the [User Tools/Counter] key.
Posted on Sep 16, 2013
6ya staff
SOURCE:
Erase fax memory on epson workforce 3620
If you see an error message telling you that the product's fax memory is full, try these solutions:
  • If you set the product to save received faxes in the product's memory or inbox, delete any faxes you have already read.
  • If you set the product to save received faxes on a computer, turn on the selected computer. Once the faxes are saved on the computer, they are deleted from the product's memory.
  • If you set the product to save received faxes on a memory device, connect the selected memory device containing the save fax folder to the product. Once the faxes are saved on the memory device, they are deleted from the product's memory. Note:Make sure the memory device has enough available memory and is not write protected.
  • If the memory is full, try sending a monochrome fax using theDirect Sendfeature or sending your faxes in smaller batches.
  • If the product cannot print a received fax due to a product error, such as a paper jam, the memory full error may appear. Clear any product errors, then ask the sender to resend the fax.
May 24, 2017 | Epson Office Equipment & Supplies
How do I set up speed dialing on my HP Officejet 5740
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Feb 25, 2015 | HP Office Equipment & Supplies
Can't fax because the fax log is full and want to know how to erase
HI...............
How to Delete a Fax Log History on an HP????
The HP printers come with the HP Solution Center software. The software allows you to adjust settings, transfer images, send a fax and make copies right from the control center instead of using the printer control panel. When you make a fax, receive a fax or block faxes, a log is kept in the HP Solution Center. You can use the software to view faxes and delete a fax log history.
Difficulty:Moderately Easy Instructions
    • 1 Open the HP Solution Center by clicking the "Start" button. Navigate the mouse to "Programs" and click on "HP" to open the drop-down box. Click on "HP Solution Center." If you have the "HP Solution Center" icon on the desktop, you can click the icon to open the software.
    • 2 Click on "Settings." A drop-down box will open up. Click "Fax Settings and Setup," which will open another drop-down box. Click "Fax Log," which will open the fax log window.
    • 3 Read the "Sent Log," which is the first tab on the window. The information will tell you the date, duration of the fax, name of the fax, fax number, how many pages and the status.
    • 4 Click on the first fax in the log to highlight it. Click "Delete" at the bottom of the window to delete the fax. Continue this step for each fax until every fax you want deleted is gone.
    • 5 Click on "Received Log" and delete each fax. Click on "Blocked Faxes" and perform the steps again to delete each of the faxes in this log that you want to delete.
HOPE THIS SOLUTION WILL HELPFUL TO YOUGOOD LUCK.................
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
How do you delete contacts?
What brand is the machine? Most machines have a setting button that you can scroll through to delete or add contacts.
Dec 28, 2010 | Office Equipment & Supplies
A incorrect fax number got loaded into the memory by mistake. How do I delete it. It is a Pixma MX320 model
If you mean the fax number for your fax machine, you should be able to press the Fax button on the printer and then press the menu button, then go to settings. You should be able to change the original set-up information, including the fax number and other identifying features for your faxes.
If you mean for memory for other fax numbers, you should be able to to to the directory in the settings and edit or delete the memory settings much the same.
Sep 23, 2010 | Canon PIXMA MX310 All-In-One Printer
Using the fax machine of Panasonic KX FT981, how can i add a contact (including its number) into the phonebook ?
Panasonic KX FT981
I am unable to rcv fax message because memory full messsage is diplaying.
How to delete memory
Pls help
Feb 24, 2010 | Office Equipment & Supplies
Fax job in memory that will not clear. Canon 2050P
1)Open the One-Touch Speed Dialing panel, then press 'Memory Reference'.
2)Use up or down arrow to select 4.DELETE DOCUMENT. 3)Press 'Set'. 4)Use up or down arrow to select the TX/RX number you want to delete. [you can check the documents stored in memory by pressing < or > ] 5)Press 'Set'. 6)Press * to delete or # to cancel deleting. 7)Press 'Stop' to return to standby mode.
Reference page 8-8 in Canon LC2050P user guide.
Dec 01, 2009 | Canon LaserClass 2050 Plain Paper Fax
How to I delete my fax machine memory? It says Memory Full and I am not able to send a fax. Please help me. Thank You My fax machine model is Canon FAX L120
Hi
Go to Control Panel>Double click of Printer & faxes >It will open up a window you need to delete all tasks from that. If it still doesnt help contact Canon people for further assistance :
http://www.usa.canon.com/consumer/controller?act=ContactCanonAct
Thanks
Rylee
Jan 08, 2009 | Canon L120 Fax Laser Printer
Faxes sent from PC do not delete from print queue.
its in the fax preferences option...on the fax icon right click and go to properties..somwhere in the preferences should be an option to select automatically delete sen faxes..or something like that.
Aug 30, 2007 | Brother IntelliFAX 5750e Laser Fax
How to clear the memory
Press FUNCTION key then 9 key. The display will ask you to ENTER FILE NO. OR ^. You want to enter ### as the file number and press SET to delete all files. (You cannot delete the file while it is being sent). The display will then show DELETE ALL FILES? 1:YES 2:NO. Press 1 to delete all files.
Jul 25, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Open Questions:
See all Lanier Ld 040 With Feed, Print, Scan, Stand - 35k Questions
Lanier Ld 040 With Feed, Print, Scan, Stand - 35k Copies Logo
105 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
