SOURCE: I have a homelite leaf blower model ut08544 that will not start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
SOURCE: homelite yard blower won't start
1st how old is the gas and 2nd how long did it sit for since you last used it? If there was any old fuel left in before now (more than 14 days) than it is possible your carb needs cleaning. If it's less than 14 days then you might want to check the compression. IF you have good compression, then you might want to take it to a service center to have it diagnosed.
SOURCE: will not start
Homelite leaf blowers that use whats called a half crankshaft system are prone to many problems. Whats a half crank system you ask? If there is a small aluminum plate that attaches to the side of the engine by the gas tank you have one of these. Usually held on with 4 small bolts. I just got rid of a Homelite Vac Attack 2 that had spark and compression but the compression checked low about 75 should be 90 or better. What happened, a head bolt came loose and the engine ran lean causing the fragile rings on the piston to heat up and when that happens they loose their outward spring that seals against the cyclinder walls. A simple compression check using a gauge and not your finger will tell you that. Other causes could be less than normal spark, or maybe the exhaust port under the muffler has carbon build up or the muffler is plugged up also Check all bolts, and nuts to make sure they are tight.
Glenn
St. Paul, MN
"top of the gas tank where the gas tube fits into the tank"
I assume you're describing the gas tank cap. if so, the o-ring is missing from the gas tank cap. You can find those at hardware stores.
SOURCE: How do I switch my Homelite Vac Attack II to a
Here's an online manual you can download to walk you through it.
http://lawnandgarden.owneriq.net/manuals/mfg/homelite/vac_attack_ii_blower_vacuum_zr08107.html
Hope this helps.
