SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
SOURCE: Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get
more info there.
Reset your Toners and
Imaging units for Bizhub and CF series.
http://www.chipreset.eu
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
SOURCE: how can u resolve all lights blinking on minolta
Unplug from PC, unplug from wall, leave unplugged for say 5 mins, and then plug back into the Wall, then, reboot PC, then plug into PC. Now should be OK. If NOT please use the manual below to troubleshoot whats wrong.
http://kmbs.konicaminolta.us/content/products/models/magicolor1600W.html
