Question about Hotpoint Aquarius WMA42 Front Load Washer
I have a Hotpoint Aqualtis with error code F-05. I've found a few answers on different sites, but they all say I should drain the water out of the hose. I've unscrewed the hose but nothing comes out of it! The machine is half full of water so I really don't want to open the door manually and flood the kitchen out. Does it sound as if there's a blockage in the hose rather than the filter? If so I'm stuck, as I can't pull the machine out on my own!
    New Friend:
  • 15 Answers
Try blowing hard up the drain hose, don\'t ingest any bugs. Use a wet & dry vac to suck and blow the hose.
Posted on Sep 19, 2013
4 Suggested Answers
SOURCE:
  • 14 Answers
SOURCE: Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Posted on Dec 30, 2007
  • 9 Answers
SOURCE: water every where
These machines have a common fault. If yours has no visible filter, the filter is in the rubber waste tube, just below the drum.
Most faults on these machines are due to a blockage or build up of sludge and lime scale in this area.
This also affects the pressure switch, which is linked by a plastic tube to the same place! This will cause the machine to stick, and not spin, otr to spin with water in the drum causing vibration.
Firstly check the outlet hose and the plumbing where the outlet goes to for signs of sludge and lime. Unless you have very soft water or a water softener, there will be some! Usually lots!
Clean this out.
Disconnect the machine from the mains and the water supply and pull it into a clear area.
Put a thick cloth on the floor and gently lay the machine on its left hand side, looking from the rear,
Undo the small panel on the back and you will see the black rubber concertina hose, pressure chamber and pump, which are now all easily accessible from the rear and the botom of the machine.
Undo the circlips with a screwdriver and the special plastic clips with a pair of pliers by twisting each part in the opposite direction.
Take the whole hose off. You find a filter and a "ping pong ball" inside this.
Clean it all out as thoroughly as you can. At the same time clean out the plastic pressure chamber and the pump. you might need to use a proprietary limescale remover or vinegar to do this.
You will usually find a few buttons, plastic items, paper, couins and a load of sludge!
Put the whole lot back, The plastic clips slide together with a toothed grip.
The whole job should take about half an hour and the machine will be like new.
Posted on Feb 29, 2008
barkencoa
  • 3463 Answers
SOURCE: WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Posted on Jan 11, 2009
I have a hotpoint aqualtis and i have a fault come up code fo5
F-05 is indeed the water outlet blocked. You need to clean it out, also possibly the pump, & Hoses.
http://www.howtomendit.com/answers.php?id=157950
See above.
http://appliancejunk.com/ge/washer/31-9135.pdf
Service manual above.
Aug 06, 2010 | Hotpoint Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
F-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Apr 01, 2009 | Washing Machines
Hotpoint Aqualtis Error code F11
please could someone help as i have the exact same problem with my aqualtis zqxgf149,exactly as above,fitted new pump myself and its now emptying the water but wont spin and in wash cycle f11 comes back up
Jun 27, 2008 | Washing Machines
F-05 error code Hotpoint WT746
how do i fix error f-05 on my washing machine
Apr 02, 2008 | Washing Machines
Error code f 05
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump. The fault is associated with drain out (pump blocked or restricted in some way). Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Sep 17, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
217 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
