please help have same issue need a code to use my dell tv with my direct tv universal remote.please help have same issue need a code to use my dell tv with my direct tv universal remote.
You can't post conmments that contain an email address.
could not find your brand at Directv.com but this may work: "
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the code "991" followed by the "device number"
for Televisions
for "AUX 1" devices - VCRs or DVDs
for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key. "
Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
"This TV utilizes new remote control signal codes and may not be compatible with your existing universal remote (e.g. satellite box remotes, cable box remotes, generic universal remotes, etc.). Over time, newer universal remote controls that become available should pick up the new TV codes."
the remote control code for DirecTV with Olevia 242T or 237T (37' or
42') model is 11610. this code will power on/off and volume up/down the
buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to olevia.com - accessories - remotes.
The RC64RB has more codes in it. Unfortunately, it is an extra $25. BUT, it is backlit, which is very cool at night. With my RC64RB, I get 16 codes to enter for your TV (Emerson HDTV).
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
if you have gone through all of the programming codes; you will just have to use the remote that came with the TV set. there is no way to program more codes into the remote, due to its list of codes it was made with can not be updated. i hope this helps
