Televison & Video Logo
A
Anonymous Posted on Sep 16, 2013
Genesis hydrovac extreme instruction manual - Televison & Video
Colin
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 26, 2014
Colin
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1593
Points
I am trying to replace electrical cord on Genesis Hydrovac extreme vacuum cleaner and can't separate two outer casing/housing elements ( only two screws).
Accidentally tipped my Genesis Hydrovac Extreme ii 2 over this morning, water from the vaccuum got into the top part where the motor is, has this happened to anyone before?
If the water was clean and you let it dry out comletely, you might get lucky.
Otherwise a new motor and control unit/power switch may be required.
2answers
My Genesis Hydrovac Extreme is leaking water where you connect the hose.
most likely if leaking at the connection is the hose tight on connector. It is leaking where you can see it make sure and when you look at it the leak is it before or after the hose connection?
Genesis hydrovac plus is leaking water
There is a seal or an O-ring somewhere that is bad. Replace and restore pressure it should work. Where the most water comes out is where i would start.
Feb 18, 2022 • Dishwashers
Manual for a secondhand genesis hydrovac plus
Contact manufacturer to request assistance.
https://verimark.co.za/genesis-hydrovac-plus.html
Cnr Witkoppen & Riverbend rd (Entrance through garage), Randburg South Africa
[email protected]
0860 005 005
Genesis hydrovac extreme thin wire from the amshire/motor to brushes when switch on sparks and broke off
You're going to need to have to get the motor repaired at an electric motor shop
Nov 17, 2014 • Vacuums
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
