Dishwashers Logo
Posted on Apr 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Glasses and dishes have a white film after cycle is finished and soap does not disolve
Mike
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 677 Answers
  • Posted on Jul 26, 2009
Mike
Expert
Level 2:
Prodigy:
Answers
677
Questions
0
Helped
366255
Points
782
The problem is hard water. go to www.dishwasherfilter.com. they have a product out that is made to solve this problem. it is very affordable and works amazing!
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Apr 16, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
2845
Points
13
Sounds like hard water. A good rinse product like JetDry should help but a water filter/hard water management system may be in order
Glasses have a white, chalky film around the top of glasses
This due in part with the government mandate to remove phosphates from detergent.
Several things can be done to improve the clean appearance of your dishes.
1. Start a wash cycle with no dishes and no soap. Once the wash cycle has stated and water is circulating,open the door and pour in one quart of white vinegar and resume the wash cycle.
2. Use a detergent named FINISH.
3. Use only the recommended amount of detergent.
4. Periodically use a product named LemiShine.
Taking these steps will improve the quality and appearance of the dishes.
On a final note: too hot water temperature can cause etching in glasses and only a lower water temp will prevent new glasses from etching.
Jul 24, 2011 • Dishwashers
tip
We had an ongoing battle with white film on glasses and dishes, inside...
<p>If your <b>dishwasher does not seem to be cleaning well</b> anymore and you are getting<b> residue and film left on your dishes</b> then you need to read this.<br /> <p><br /> <br /> <p>Since July of 2010 the US Government has mandated that <b>dishwasher detergents</b> contain no more then 0.05% phosphates in them. The Detergents before this had contained up to 8.7% phosphates. The restrictions were for 16 states but many companies then dropped the phosphates from detergents to all states...<br /> <p><br /> <br /> <p>Now if you are having the <b>scum, film, and white residue problems</b> in your <b>dishwasher, </b>there is hope.<br /> <p><span>There is a product that you can buy that will compensate for what the makers of the </span><b>dishwasher detergents</b><span> have left out. This product as commonly know as </span><b>TSP</b><span> or </span>(<b>Trisodium Phosphate</b>).<br /> <p>By adding this to your dishwasher, you can manually add back the phosphates to your dishwasher and enhance the cleaning process.<br /> <p><br /> <br /> <p>Now the nest question...how much TSP do I add to the dishwasher?<br /> <p><br /> <br /> <p>For many dishwashers, waters, and for normal loads you will find that a tablespoon or two is all that you will need. For very hard to clean dishes and for some types of water you may need to add up to a 1/3 cup of TSP. <br /> <p><br /> <br /> <p>If you are having problems with your <b>dishes not getting clean</b>, a <b>black or scum film</b>, or <b>white residue</b> being left on your dishes at the end of the cycle, then I would start with a tablespoon or two and then adjust from there. Figure out how much you need to add to you dishwasher to make your <b>dishwasher detergent </b>work correctly for you again.<br /> <p><br /> <br /> <p>To best part is that you can have <b>clean dishes </b>coming from your dishwasher again!!<br /> <p><br /> <br />
on Mar 31, 2011 • Dishwashers
I have a Maytag dishwasher model #MDB7160AWW. I am finding a cloudy residue on my glasses and cups on the top rack. Our water is hard. When the washing cycle is completed, there is still soap residue...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Apr 14, 2011 • Dishwashers
My dishes are coming out with a kind of film on them -- especially the silverware and glasses. Now the plates even look like they have a film on them. The dishes are often still dirty.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
l'l
My dishwasher is leaving residue or soap scum on my dishes...
heatman101
0=0
2answers
Dishes not coming clean, film ring on glasses and dried grime on the utinsels. Have run through twice with vinegar, not sure what to try next. Checked basket/drain and it was not blocked just has a small...
That sounds more like a problem with your soap not disolving completly. Try these few simple things. First, run your hot tap at your sink until it gets hot, then start your dishwasher. What this will do is ensure that your "prewash" is using hot water.
The next thing, is you want to select the "heated wash" or "hi temp wash" option with a "normal wash" cycle. What the heated wash will do is ensure that during the main wash the water gets boosted to 140 degrees wich is the temperature that your soap breaks down at.
White film left on dishes is a classic indication that the soap has not disolved or broken down completly.
1helpful
2answers
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
2answers
HElp Dishes not coming clean
3answers
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Top Dishwashers Experts
Mike Cairns
Mike Cairns
