SOURCE: Canon MP500 Printer head error
Print heads for nearly all printers are rated at 2 years. You may also need to clean the tube from the resevoir at the ink supply to the cartridge and clean the working resevoir on the cartridge as well. If you are up to this challenge there is a how-to at your manufacturer's web site or you can have a tech do it. Most people, when they realize how inky you will be getting choose to have a tech do this.
It is best to use 100% denatured alcohol, from your hardware store, to clean these parts and tubing. But, you must take precautions.
DO NOT USE DENATURED ALCOHOL UNLESS YOU READ AND FOLLOW THE DIRECTIONS ON THE BACK OF THE CAN.
I'm not kidding about the precautions. I do all this stuff outside when there is a breeze in the air and then I stay up wind of my work.
If you have any questions whatsoever just feel free to comment back to me.
Regards,
Worldvet
SOURCE: The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
Print Head Cleaning / Head Refreshing
If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
Reseat Print Head
Reseating the print head is seldomly needed to be done.
Automatically Aligning The Print Head Position:
CAUTION:
a. Do not try to manually move or stop the Print Head Holder.
b. Do not touch any metal parts.
IMPORTANT:
Handle ink tanks carefully to avoid staining clothing or the surrounding area.
IMPORTANT:
a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
Manually Aligning The Print Head Position:
When automatic alignment does not work well, align the print head position manually.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
(1): Bad example (Least solid box)
(2): Good example (Most solid box)
(A): Column
(0): Select pattern number with most solid image
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: how do I clean the heads on my Canon i450 printer
# Hold the
cartridge upside down, with the bar-code label facing you and take a damp paper
towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
CF
SOURCE: canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
SOURCE: Print back to back with Canon LBP 2900
If the printer does not support double sided printing, you need to take the printed page and put it back into the paper tray upside down to print on the other side of the page.
If you have a document several pages long then you need to print a page at a time. The odd page on one side and the even page on the other side.
