i dont understand what you mean by check the video format?i dont understand what you mean by check the video format?
AnonymousApr 25, 2009
I have the same problem no color when using dvd. no pal or ntsc settings in menu I have the same problem no color when using dvd. no pal or ntsc settings in menu
You can't post conmments that contain an email address.
It sounds like you have a standard problem. Is the TV you are using, that gives the black and white picture, the same as the other ie, both NTSC or PAL and both on RGB or Y-C or S-Video? Check to see what is required and set the DVD player accordingly. Hope that helps.
will you check the video settings in the menu?
look for NTSC, PAL or other versions that is right for the tv.
If there is a Automatic setting better use it.
An NTSC dvd wont play the picture well on a PAL tv set.
success
try to set the menu botton or setting the video of your remote control of your dvd,then find video setting if PAL ,SECAM OR NTSC OR AUTO .then chose [email protected]) rongxin.
it has something to do with your TV's video system and your player's video system...they should match...that is,PAL-PAL,NTSC-NTSC and etc..or if your tv has a multisystem then just set it to AUTO. Check on the dvd menu for the video format maybe that´s the problem , hope this helps , AJ
what video device do you plug in to your TV screen, DVD player/VCR or game console?
If you still have the owners manual of your TV screen, look for instruction regarding Color system or video system. this menu will allow you to change color sytem from PAL to NTSC or AUTO system. most likely the reason why you have a black and white color from vidoe input is because of system color compatibilty from your input device to your screen.
Or if your using a dvd player, you can also try accessing the "setup" button and look for video setting. from the video setting there will be selection to choose from: PAL , NTSC, AUTO . always select "auto" so that the color system of your DVD player can change from PAL to NTSC deffending on your TV screen system setup.
