Konica Minolta bizhub C351 All-In-One Laser Printer Logo
Bernie Posted on Sep 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica Minolta Bizhub C351 will not let me change IP address?
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Dec 30, 2014
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910560
Points
11959
GO to:
1. Admin Settings
2. Network settings
3. Common Settings
4.TCP/IP
Set for static Best way Pick a IP address you can use
DHCP mode means the server will decide which Ip address the copier gets NOT GOOD!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Patricia campbell
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 10, 2013
Patricia campbell
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
274
Points
I need to change my internet provider address. please
3 Related Answers
Anonymous
  • 8 Answers
  • Posted on Feb 02, 2008
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
A
Anonymous
  • Posted on Mar 23, 2008
SOURCE: getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Anonymous
  • 44 Answers
  • Posted on Nov 29, 2009
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
I have a Konica Minolta BizHub C351 need to know how I can set up the ip address in order to be able to print to it. And any advice you can give me on the drivers using Microsoft Windows 7
Go to Konica Minolta web site US I assume down load driver for your machine. GO to Admin Settings PW 00000000 or 12345678 default. Network settings common setting to get IP address info
Our Server was just changed; I cannot scan and retrieve that scan on my computer. How can I change the path on the Bizhub?
go to pagescope (web interface) by typing the IP address of the copier into any webbrouser address line. then go to scan and wallllah?? you got the settings
Describe your Konica Minolta bizhub C351 All-In-One Laser Printer Problem how to Assign an IP address to the machine
go to utility/counter button
go to admin
type in password
go to tcp/ip
go to second page
type ip address in
done
How do I find and reset the IP address on a Konica C351
Utility/Counter button, Administrator, 12345678 or 00000000 is password
select network setting. You can make changes to IP, DNS, Gateway, Subnet, SMTP , ect.
I HAVE A KONICA MINOLTA BIZHUB C351, I WAS MESSING WITH THE NETWORK CONFIGURATION AND NOW I CAN'T PRINT, IS THERE ANY WAY TO RESET IT TO FACTORY CONFIGURATION??? ANY HELP PLEASE...
First of All, Assign an IP address to the machine, if you already assigned the IP address, then Ping it from one computer to check its connectivity, now remove all the printers and printer drivers from your computer, and re-install the printer. if you want to reset the machine, then press the "utility/counter" button and turn the machine ON,(keep the button pressed) now from that machine reset the machine.
1helpful
2answers
I have a konica bizhub c351, I have changed my network here at the office. This IP address is 192.168.15.50 and now I need to change it to 192.168.0.50. Can you help me?
1.press the utility/counter button
2.select the administrator setting button
3.enter the password 12345678
4.select network setting
5.select tcpip setting
press forward button until you reach the tcpip addres section then you can change the address
Adding a new computer to scanning network of konica bizhub c351
Manuals:
http://help.bt.konicaminolta.ca
#1 Create one-touch.
From here make selections until you find the one you want.
or....
Use your Web Browser to log into the device by entering the copier IP Address. From here you can create one-touches as well, and is easier.
2answers
How to set scan for a new person on bizhub c351
After pressing "scan," press "Direct Input," then "Scan to E-mail." That will come up with a digital keyboard with which you can enter the e-mail. You'll have to type out the whole address, as on my printer (even though I have the manual) I can't seem to find out how to save it so you don't have to type it in every time...
However, after inputting the e-mail address, press "Start" and it should scan to the e-mail.
1helpful
2answers
I cant install konica Minolta bizhub C351 on my mac. please HELP
To print via IP on MAC  type IP address in queue type print ,name the printer and  the correct driver/ fy...35/
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
