SOURCE: dishwasher is stuck on the rinse cycle
make sure the float or metal probes in the unit are clean.they sense water and if anything is on them it will cause a malfunction in the unit.
SOURCE: Hotpoint FDW60 problem
Wash motor either seized up/ faulty or the is an itme jamming up the impeller. Regards Advisor
SOURCE: FDW60P dishwasher. Hotpoint Aquarius Control panel not working
I phoned Hotpoint. Was told to switch everything off and take the plug out for ten minutes - I didnt do that before, I just plugged it straight back in. I did this and was able to run the machine during the night on the programme I wanted. At least if it happens again I know what to do.. This solution will cost you nothing.
SOURCE: FDW60 has standing water in the bottom and will not fill up
You most likely have a stubborn clog in your kitchen drain. Try filling the sinks with warm soapy water and then letting the water drain while also turning on your garbage disposal. Sometimes the extra water pressure will help push the clog through.
