Open it and try to clean it, may be a dirty laser as to why it is not reading, or something faulty with the dive internal mechanism. I would also try a different power connector and data port.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/chad_70dccdc9090b1a75
SOURCE: GSA-H55L problem
your dvd writer have warranty
so you contact LG customer care is better
you can use their free service warranty
SOURCE: HL-DT-ST DVD-RW GWA-4082
ya it ll work... first change the cd to write mode ..hence not able to burn files...
SOURCE: LG DVD RW drive not detecting DVD/CD
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters.... (if lower filter is not there then leave it)
RESTART YOUR COMPUTER THEN THERE YA GO!!!! HOPE THIS HELPS
SOURCE: CD PLAYS BUT DVD WILL NOT PLAY IN MY LG DVD/RW
Hi, Sometimes these problem arises if any virus attacks your system, so first make your system virus free. And if its not the problem then your lense in the dvd drive is not working properly, its better to make repair it so that it works properly.
SOURCE: When I try to play DVD, nothing happens.
change the lens of DVD. its a common problem. due to over use.
try a firmware update, this info should be available from LG.
