Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley Heated Hand Grips not working
There were installed by my local stealer, worked for one year.
I do not have the wiring diagram to check.
Fuse is good - there is continuity to ground when ignition is on.
Any thoughts would be helpful...
THX
  • Anonymous May 05, 2009
    My heated hand grips on my 2007 Heritage Software are not working
  • 20 Answers
The harley heated handgrips are notorious for failing.  Some people have reported finding a loose connection on the ground wire, like they did not crimp the terminal on the end of the wire at the factory.  If they are wired externally of the bars (almost impossible to wire those any other way) then it should be easy to follow the wire down to inside the headlight bucket or in the nacelle or dash, (depending on what model bike) and check the connections.  If both grips quit at the same time then it's probably wiring.  If one quit first, then it may be the grip itself.
If you need to replace them, I would highly recommend not buying the HD brand anymore, and instead choose Polly grip heaters.  They are made for snowmobiles and have a long list of benefits over the HD type: - fits internally in the bar end, so you can use any grips you want - cost $35!!  compared to $250 for HD - easy to install
I have installed over 7 sets in my friends bikes and not one single failure.
Posted on May 26, 2009
  • IronHorseman Dec 22, 2010
    Hi, Flyin Brian (or anyone else with an experienced answer). I have a 2009 Electra Glide classic with the stock 1" handlebar and electronic throttle in the handgrip. Can the Polly grip heaters you mentioned work with this setup? Have you installed for this application? Which Polly grip heater, from their website, would you suggest (since they say their snowmobile grips are not suitable for motorcycles because the snowmobile ones run hotter). Thanks so much.
    d_o_u_g_@hotmail.com
  • Tony Smith Apr 03, 2014
    My starter switch went bad, and in the process of taking the Right grip assembly off, I unplugged the two-pronged wire assy. on the end. This caused my grips not to heat. Once I plugged it back in, the grips started working.
I have a 2004 harley low rider and just changed my switches to chrome, when i reconnected everything my hand grips got hot with dial turned to off.
Posted on Jun 26, 2009
SOURCE:
How to add heated grips
Hi, Yvette always liked that name, it all depends on the year, make, and model of your motorcycle, for me to find a matching video they are all about the same unless you have TBW (electronic throttle) so here is a video for Harley Davidson. Good luck and have a nice day. How to Install Harley Brand Heated Grips on Harley Davidson Motorcycle...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 30, 2015 | Motorcycles
Wiring heated hand grips
Hi, Flyers98765 I would really love to help you but due to the magnitude of yesterday's solar flare the batteries in my crystal ball are dead and my mental telepathy headset circuitry was melted. I need the year, make, and model of your motorcycle please click on the word "COMMENT" below and provide this information in the box that will open and then click on the green comment box in the bottom right-hand corner after it posts I will receive an "ALERT" icon that will allow me to respond to your information.
Good luck and have a wonderful day.
May 06, 2017 | Motorcycles
How to install heated grips on 2010 ultra classic
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Jan 28, 2012 | Harley Davidson Motorcycles
How do i get the wiring through the bars to the heated grips.
If you remove the pass switch on the left hand switch housing you have room to fit the round rocker switch in the his housing. This makes for a very clean installation. Since in the day time I ride with high beams on the pass switch was of know use to me plus flashing your high beams at a car you intend to over take seems to produce a rather random out come. I traced out the diameter of hole I would need with a scribe and then trimmed it out with a Dremel, test fitting the switch as I went. Much safer then trying to drill a hole that large in a piece of plastic.
Left Side
Right Side
The empty three wire plug under the nose fairing is intended for the factory heated grips. I cut of the plug and wired into the power here. There are three wires, 12v hot, 12v signal, & Ground. The 12v hot use the fuse in the fuse box marked for the heated grips but remains hot even when the bike is off. So I wired in a 12v relay using the signal wire to switch the 12v hot with the ignition. This will prevent dead batteries if I leave the heated grips on or if a passer by feels the need to flip switches on my bike; it's happed before! You will be able to tell which is the 12v hot and 12v signal by pulling the heated grip fuse and seeing which wire remains hot.
Relay
hope this helps
John
Jan 16, 2011 | 2007 Triumph Tiger
1995 Honda ST 1100 Pan European heated grips not working
Hi, Malcolmpaine for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Thread Hondaline heated grips trouble shooting
HONDA ST1100 HEATED GRIPS INSTALLATION
HONDA ST1100 ABS BIKE 1990 2002 WORKSHOP SERVICE MANUAL Download Manuals... $14
https://www.partsfish.com/page/oem-parts-for-honda
Honda ST1100 Owner Manual
Nov 12, 2010 | 1995 Honda ST 1100 Pan European (cbs-abs...
Yamaha YZF R6 won't fire(year 2000)
Well, the spark for the plugs and the heated grips are both electrical. I suspect that you either have a blown fuse, (check this first) or you may have crossed the aWRONG wires when you installed the grips. Do the grips get hot? I don't think you did anything to the electrical system when ot fell, as it would have stopped right then, at impact. But in that you have installed an accessory without any technical knowledge before your asked.... I thinmk that THAT is where you are going to find the problem. IF you still cannot locate the reason for no fire, try these ideas. 1) wiggle your ignition switch back and forth several times, and trun it on/off sevaeral times as well. Try to start it each time you try something else. Check to make sure that the plugs are not damaged, but as you're getting NO fire these things are unlikely. (but need to be checked to be SURE that they are not the problem) Next, check the HOT wire (12Volts) TO the coils with a testlight or Ohm-meter. Be sure that there is fire TO the coils. It is likely that you have knocked off,shorted, and blown the fuse to that wire or similar during the installation of the heated grips. IF you need more help, come back and let me know what is happenoing. Thanks for calling on FixYa.com
Apr 13, 2010 | 2000 Yamaha YZF-R6
Harley Heated Hand grips failed a third time.
Hi, Skipglide the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Heated Grips Troubleshooting Harley Davidson Forums Harley Davidson service manuals for download http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm free owners manual
Instant Repair Help over the Phone to speak to me personally $4
Jun 07, 2017 | Harley Davidson Motorcycles
Heated hand grips
Hi Bjbutch, for more information about your question please visit the websites below. Good luck and have nice day.
Mar 08, 2009 | 2008 Harley Davidson FLHRC 105th...
Lands Phones Logo
4,489 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
