Rohl U.4759APC-2 Perrin and Rowe Bar Faucet with Metal Lever Handles P Logo
Greg Credi Posted on Sep 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New Perrin and Rowe hand sprayer leaks on assembly
Bill Johnson
Level 2:
  • Expert 306 Answers
  • Posted on Oct 02, 2013
Bill Johnson
Expert
Level 2:
Answers
306
Questions
0
Helped
183565
Points
673
Hello, It is a defect in the product, you must replace the and sprayer.
Perrin & Rowe U.5383 Shower Head Diverter - how remove spindle?
The best form of marketing available! One of powerful SEO services! We do High PR Backlink service, they're natural and strong backlinks.
Read on: high PR backlink, high PR backlink service
Oct 08, 2022 • Home
Garden hand pump sprayer not presssurising
There is probably a leak somewhere in the hosing or gasket. As you try to pump it up, take some soapy water and pour it around sealed areas of the sprayer. Look for bubbles as the sprayer leaks air. Also check the nozzle of the sprayer for a clog. Rinse it thoroughly with hot water until it has cleared any blockage.
My plumbing supply house was suppossed to order my Rohl shower set up with cross handles (RA4914 & 4912). Instead he ordered the lever handles. My sink faucet (RA1408) was ordered correctly with the...
Nice.
Paying that price for your shower faucet, I would think the supply house would work with you on that. eBay shows cross handles so they are available.
The plumbing supply store should be able to order what you want.
I have a Perrin and Rowe Diverter valve U.5383 for a hand held shower that I need to disassemble to replace the spindle. Is the right hand side housing threaded? There is a hex nut on the housing (exposed...
Soak the unit in very hot water 50/50 with white vinegar for 2or 3 hours to loosen the lime in the threads and try it again. Keep the water hot no boiling but hot.
Perrin and Rowe, Mayfair Series.- how do you take the perrin and rowe handle apart. The top of the handle has a ceramic disk inserted that says "Hot" or "Cold" and I am not sure whether...
The disk is glued on, but no need to remove. The entire section below the handle spins off, but most likely not by hand (hot did, not cold). I used channel lock pliers and some wood strips that I fabricated to prevent damage to the finish. You then need a thin 17mm wrench to remove the valve. I presume you are having problems turning the cold water handle? Seems common, I am working on it now, looks corroded so I am soaking it in 50/50 vinegar and water.
1helpful
Perrin & Rowe Mayfair kitchen sink faucet sticks
I wwould suggest contacting the source importer for this one, Rohl, at 1-800-777-9762. Be prepare with as much ownership information as you can. As a high quality high end faucet, all parts will most likely have to be special ordered so you want to know that what you are ordering is what you really need.
Mar 30, 2010 • Home
Top Rohl Plumbing Experts
vince
Paul Carew
john h
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
