My Samsung HLR5667W DLP won't come on. The Lamp indicator lite blinks for about a minute, then the system shuts down again. The lamp is illuminated in back but now menu or picture. It has been doing the freeze picture thing occationally for a year or so. That is when the picture freezes then goes black and the tv restarts and worked fine untill the next freeze.
SOURCE: SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
got mine working better unplugged the sound and wiggled the plastic coated wire above the large fan works but freezes maybe once in a day some days never have the sound running through the receiver (surround) I shut it off and it comes back on when it does freeze figure loose connection
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
SOURCE: Black screen with a Blinking lamp in the front
Hi my name is Vince and I have a samsung dlp (model hl-r5667 w). Its about 4 years old and i have no warranty for the tv. Recently my lamp went bad so i purchased a new lamp and installed it myself and about 45 minutes later a there was loud pop and the screen wet black and the sound went out as well. Also the tv started making a loud humming noise. I had a tv repair guy come look at the tv and from the second he walked in the door he was on his phone arguing with some one for ten minutes and seem like he did want to work. Well he finally got after the call and told me that the light engine needs to be replaced. Do you think I should get a second opinion or does that sound about right? The only reason I ask is because he did seem like he wanted to work on the tv and had something else going that was more important. Thanks
SOURCE: Samsung Dlp HL-R7178w not turning On.
If all 3 leds blink, it can be the lamp, ballast (lamp driver), color wheel, or dmd board (all are engine parts = engine failur). its usually the lamp, but you can listen to troubleshoot. when it turns on, you will hear the fans come up (humm..airflow noise), then you will hear the colorwheel (high pitched squeel.. it will come up to speed) and then the ballast will fire up the lamp.. if the lamp doesn't fire, you will hear the spark gap fire (a 1 second buzz noise indicating bad lamp).. the gap will fire 3 times, they tv will then retry again and again until it shuts off and kicks out the error. this power up path will help you listen to find your problem. i can assist further.
SOURCE: no picture on my samsung 61" dlp.
The color wheel if bad enough, will cause the lamp not to light. If the lamp is truly bad, you can't usually tell by just looking at it unless of course it is broken.
I hauled it in to a service shop, laying on its back on top of many pillows. No problem there, so don't rent a truck if you have plenty of pillows or other soft support. They say it is the "Main Board". According to Samsung parts, that main board is on "back order for a minumum of 4 weeks. Real nice. A $3000, 3 year old TV needs $400 worth of repairs and the jack ***** at Samsung can only say "you should have bought a service agreement." All financial experts agree to self insure plus what good would that be? They are only for 3 years anyway and you bozo's don't have the parts! I' m sure the agreement would have been more than $400 so I'm ahead. I'll never buy another Samsung product. They obviously built the mainboards wrong, or there wouldn't be a run on them now.
