2 8 . . . . this will be 2,4,6 and 8 pins (from left to right) . . . . . this will be 1,3,5,7 and 9 pins 1 9
Power Led + in pin 2 Power Led - in pin 4 Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom) Power Button GND or - in pin 8
HDD Led + in pin 1 HDD Led - in pin 3 GND from Reset Buttom in pin 5 # from Reset Buttom in pin 7
Led 2 flashing indicates the the computer is undergoing POST (testing components). If it flashing then something is wrong, usually the computer beeps a cumber of times which translates to a code eg ram error.
When led 2 is stable, the computer completed POST and is booting up through bios and then the OS.
Led 1 on which means the computer is receiving power.
Here is the download site for Aopen motherboard. Download a manual and i am sure that the locations that you are looking for wil bbe illistrated. If not their are also 4 more pages of downloads for that MB.
Generally you don't need to know jumper settings in newer motherboards. What you may be referring to is the front panel i/o connector. This has the power switch, reset switch, power LED, hdd LED, and etc.
To download the motherboard manual, please go to http://download.aopen.com.tw/userdownload_List.aspx?RecNo=6027&Model=435
ftp://ftp.aopen.com/pub/manual/mb/mx4bs/mx4bs-ol-e.pdf here is the manual that you needs i found it on the www.aopen.com website
it says for the front panel switches
attach the power led,empi,speakers,power and reset switch connectors to corresponding pins. If you enable suspend mode item in bios setup the acpi and power led will keep flashing while the system is in suspend mode
locate the power switch cable from your atx housing. It is a 2 pin female connector from the housing front panel. Plug this connector to the soft connector marked spwr
there is a diagram to show you how to hook it up if you need anymore hesitate plz give me a shout and i willl be able to assist you more
