SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
SOURCE: My Brother LX 3125 does not sew zig zag stitches
Mine did the same thing. The needle is probably to high. Do not insert the needle all the way to the top. Lower it a bit and it should zig zag!
SOURCE: I sewed small zig zag stitches with no poblem but
I would call Brother, at 1-877-276-8437 and find out what they think is the problem, and have them advise you where to take it. In the meantime, make sure nothing is up in the shaft where you needle goes in, try to clean it out. That is really a strange problem. Good luck.
SOURCE: My machine sews straight when set to zig zag and
If your using a stretch fabric, youll need to sew in a stiffner tape. if the fabric "flags" i.e moves up and down with the needle it spoils the loop needed to form a stitch. If your having problems with a stiffer fabric it could be just a bad or too thin a needle. Check threading, needle condition and setting.
SOURCE: missing stitches on zig zag with loose stitching underneath fabric
try changing the needle
adjust the top tension if nessary
