I fixed this problem; I pulled the wheel and removed the axle nut and sprayed penetrating lube around the axle and put it back together- problem fixed... I also took the rim apart and sprayed rust preventive on the inside of both wheel halves because water can get in there from washing the dog stuff off the wheels (yeah you know). I wanted to pull the hub and have a look but it must take a puller because tapping on it with a brass hammer did nothing. So make sure the axle nut is tight...Jazzy 1450 but should be the same on others...
