Check the power supply.If you have no output from the power supply try to disconnect the power supply from the other circuits ( such as the IF,audio,video,horizontal,vertical,etc.If the voltage at the power supply comes up when you disconnect a particular circuit then that circuit is loading down the power supply and you would troubleshoot that circuit.If after disconnecting the other circuits and the power supply still shows zero,then you would troubleshoot the power supply.
SOURCE: plz help me
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the music button for about 10 seconds.
SOURCE: Instructions to tune Philips tv 54cm colour TV.
Hello
You haven't mentioned about the model number of your Philips TV. Different models have different type of tuning procedures. Any way I hereby send a procedure to set it autotuned. If it Doesn't work, please inform me through Fixya, stating your TVs model number also. ok
Press "Menu" on the remote control handset, and select the installation language.
Select a language and confirm it by pressing "OK" button on the remote control.
Press ' button to return to 'Instalation' menu.
Press "Menu" on the remote control handset and select Installtion > Preferences > Location.
Select 'Home" and press "ok" to confirm.
Press ' to come to the Installation menu.
TO TUNE CHANNELS AUTOMATICLY AND TO STORE
Press "Menu" on the remote control, "Select Installation" '>' Channels '>' Autoprogram '>' Start now.
Press "OK" and allow the start installation automatically.
If you run autoprogram when you have locked channels, a messege appears asking to enter your PIN code in order to complete instllation.
Try this, if doesn't work inform me with TVs model number. OK.
