Hi, my nike triax cv10 watch is frozen, tried pressing all the buttons at once but no luck please help?
The display of your watch may "freeze" due to static electricity or recent battery replacement.
If this occurs, press and hold all four buttons at the same time.
This will erase the data in the memory and allow you to reset the watch to the factory settings.
Press and hold all four side buttons at the same time to reset the watch to the factory settings.
Hope this helps.
Hope this helps.
This will erase the data in the memory and allow you to reset the watch to the factory settings. Press and hold all four side buttons at the same time to reset the watch to the factory settings. Hope this helps.
If this occurs, press and hold all four buttons at the same time. This will erase the data in the memory and allow you to reset the watch to the factory settings. Press and hold all four side buttons at the same time to reset the watch to the factory settings. Hope this helps.
The display of your watch may "freeze" due to static electricity or recent battery replacement. If this occurs, press and hold all four buttons at the same time. This will erase the data in the memory and allow you to reset the watch to the factory settings. Press and hold all four side buttons at the same time to reset the watch to the factory settings. Hope this helps.
Press and hold all four buttons at the same time. This will erase the data in the memory and allow you to reset the watch to the factory settings. Press and hold all four side buttons at the same time to reset the watch to the factory settings. Hope this helps.
Press and hold all four buttons at the same time. This will allow you to reset the watch to the factory settings. Press and hold all four side buttons at the same time to reset the watch to the factory settings. Hope this helps.
