Yes, you can do it.
Downloading the driver will result in a file you can copy over to the flashdrive.
Just do not double-click on the file, because that will start the installation process.
In the unlikely case that the file auto-starts the installation process, you will normally have the option to Cancel the installation.
Make sure you have installed the scanner drivers for win7. I have the same printer and I can print & scan from Win XP, Win 7 & my iPad (All on wireless). Drivers for the printer & scanner must be installed.
Hi soji ... Corex Cardscan 60drivers (xp/vista/win7/win8) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Your printer supports W7 and the driver is located below. You need to first unplug the printer, uninstall it from the control panel and then restart the computer. Then download your driver and install it. HP printers need the Full Version software, not the just the driver that W7 loads when it discovers it.
Do NOT plug the printer back into the computer until prompted by the software.
WIFI dongles are very scewy anyway let alone one trying to use a third party operating system. I have never seen one that stated it was compatable with Linux so yes it prolly is a conflict with your operating system. That PC runs great with XP or Win7 buy an OEM CD off Newegg for about $99. All ur drivers are on Acers website. The only 1 u will need to load is the SD card the others are embedded in XP and Win7. If u use Win7 u may try the Vista driver 4 the SD card.
Go to the following URL: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=11446#DownloadDetailAct
Then select your OS.The drivers and software for Win7 32 bit and Win7 64 bit different. The Win7 64 bit drivers are digitally signed; the 32 bit version doesn't need the same level of security certificates (a Microsoft issue).
