You can get a new one fairly cheap. Toolpartsdirect.com there is different types to that model. Once you get it, they are not hard to change, 3 or 4 screws.
Probably need to replace bearing 6202. I took mine apart, dissambled the retainer and used PB Blaster on the bearing. It seems to be a short term fix. At least it's not operating at hyper speed anymore. Long term, I probably need to replace the bearing and maybe a new lower retainer if I can't press the bearing out.
this sander appears to use the hook and loop system, you can download an instruction manual by going to dewaltservicenet.com and typing in your model number.
I'm not sure I understand your question, but I'll give it a go.
The DW421 is a sander already. If you want to change it to a polisher, you can buy polishing pads to go on it. If you have a Dewalt polisher and want to convert to a sander, you can buy sanding disks to fit your polisher. They are installed on the spindle and I believe you can get a backing pad for it also.
could be but I would think more that there is a bearing that is rough/tight causing, sounds like time for a thorough cleaning. Unplug tool and can you more the motor/pad freely, you will get some resistance but it should turn. If not then I would look to replace them.
If pad is hook and loop style use compressed air or clean nylon brush to clean debris from hooks.If using adhesive backed dics try wiping a little alcohol across the pad surface to clean it.
