All new popcorn machines will produce a industrial smell for a short while when first heated up. It is from the oils used in manufacturing and that will stop over time.
Burned wire smell is usually associated with cleaning of the kettle. Cleaning compounds that are stuck in the carbon will create a harsh smell.
If the switch is OK and you have. Power at the kettle plug and you are not getting any heat it's one of 3 things. Burned wire inside the kettle. this is common. Or it could be the thermostat is bad or the element itself is out?
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Popcorn needs 400F to pop, if you machine is not hot enough it will not pop popcorn. You did not include very much information to help fix it, but if it is a home use popper, you cannot repair anything on them. A true commercial popper you can replace thermostats, and fix the problem.
Pls check if your popcorn pack sealed tightly and kindly inspect your equipment if the radiation is enough to heat up the popcorn. You may also restart the mircowave so that you would verify if the machine does work
use a non contact voltage detector pen and follow the wires from bottom up to bowl heater , somewhere along the way the power will stop , thats the device that needs some looking at
First, if you have another cord like this one (for example, a coffee pot cord) plug it into the popper and see if it works.
If it's not the cord, it's probably a blown thermal fuse inside the unit. Could be a heating element broken as well. If you don't have appliance repair experience, I would take it to a repair shop.
