Acer Aspire 5002WLMi Notebook Logo
Posted on Sep 15, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unwanted Shut-off I will be doing something on my laptop and it will just randomly shut off. No warning, no goodbye screen, it simply shuts off. I think that it is only happening when playing games (including when I install them sometimes). My comp and AC adaptor are pretty hot when this happens, but it has always has been like that and hasn't had this happen until recently.
A
Anonymous
Use this utility
RightMark CPU Clock Utility (RMClock)
 to keep track of temperature of CPU when you use any CPU intensive feature. temp above ~110 might shut off your computer. if temp increases its the heating problem. you can restrict the usage of cpu to lower clock by this utility so that it wont heat so much, but it will affect performance also.
Simon Clarke
Level 1:
  • Contributor 57 Answers
  • Posted on Sep 15, 2007
Simon Clarke
Contributor
Level 1:
Answers
57
Questions
Helped
20352
Points
90
Work out the airflow through the machine. Usually a fan in the base will suck air in the bottom and blow it out the side/ back. Use vaccuum to clear any dust at the inlet and compresed air to clear all vents. Always use laptop on a hard surface (not your lap!) to make sure the air flows properly and keeps it all cool.
Anonymous
Level 2:
Scholar:
  • Expert 84 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
84
Questions
0
Helped
47011
Points
167
First Charge up you battery while the computer is off. Once fully charged unplug the adapter and play the game...see if it shuts down. If not replace that ac adapter. If it still shuts down... Your unit is overheating most likely. When you play high tech games which cause the processor and fans to run harder once it gets to hot. And most times you can hear the fan running loud on your laptop. 1. check the system requirements on the game 2. Are you overclocking your processor, check your bios 3. Lower the graphics settings and features in your game.. see if it shuts down 3.Or while you are running the game do the follow hit ctrl, alt, del buttons at the same time. A task manager box will pop up. Click on the tab Performance.....what is your cpu usage? 100% if so it's running the proccessor hard. Now in the same box click on Processes, then user name, you will then see all processes that are running at that time. If you want to play the game off line...only!!! you can stop some processes from running. On the bottom right hand corner of your screen by the clock you will see icons that load up at startup. Right click the ones not in use, like virus scan, firewall, other background applications that are running by right clicking over the icon and exiting or closing the application. Now keep in mind before you go back on line you should restart your computer so your security software will reload. Other reasons would be internal cleaning, fan, heatsink replacements and so forth. Which may need to be performed by a professional repair shop. Now they do have a laptop colling pad which have worked for some people. Also these laptops can overheat quickly, do not sit them on beds, and your lap when using ventilation is important. And also you might still want to have that ac adapter checked out. If all else fail... restart you computer in safe mode...try running the game..see if it shuts down. Good luck with your games
My laptop (lenovo g560) randomly shut down.
Try scanning your computer with radarsync to know which drivers are out-of-date. It has something to do with the device drivers for sure. Update the drivers using RadarSync.
If it still not going to fix the problem then check if there's a sign of overheating after it shuts down. You might want to get it opened by a technician so that he or she can clean the air passages and fans inside your computer.
David
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Acer Aspire 7736z-4088 keeps shutting off randomly
Is the fan and vents free of dust? Is the laptop getting sufficent air flow? It sounds like power issues maybe multiple issues. Does it overheat? Difficult to say for sure. If your remove the battery?
My computer continues to shut-down for no apparent reason while booting up. It will get to bios then abruptly shutdown. Please Help!!
Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
Laptop randomly shuts down and shows a blue screen saying
Make sure you don't have any unecessary programs loading up into windows when your laptop boots up. The next time the system randomly reboots check to see if the laptop feels a bit warmer then normal. Could be that your air vents are being blocked by dust. That would cause the air not to flow properly. Take a can of air and blow the vents clear so the air can flow properly and that would take care of the problem.
1helpful
2answers
My laptop keeps shutting down at random times. I
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck
2answers
Dell Laptop shuts off
Take out the battery and only hook up the AC Adapter to the laptop. See if it still shuts off on you at random.
If it still does then try another AC Adapter and if it still shuts down randomly then it might be a motherboard issue.
Take a can of air and blow it into the air vents on your laptop. This will remove any dust or debris that might be affecting air flow.
If that doesn't do it then the only other thing to try would be to take apart the laptop and where the heatsink sits on top of the CPU, take the heatsink off and make sure there is no dirt or dust buildup on it. If there is buildup on there that would cause the laptop to shut down without warning cause that means its not cooling like normal.
At this point if you went thru all of this and you still get shutdowns then the motherboard is bad
How do i shut down my think pad? it will not cut off
In your case,
the most simplest way to shut down your laptop is to override your processing by simply holding down the shutdown button until your computer turns off (do this when all your work is saved and the "Windows is shutting down" mode is on your screen).
This idea is not recommended but will always work.
Hope I helped
- donman92
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
