Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
Posted on Sep 15, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hoover windtunnel U6439900
Vacuumed up an apron string and turned off the vacuum as it started to smoke--rubber I think. Took off the bottom four screws and checked -- one thin belt OK, 1 large belt on a large roller behind the brush--but just hanging there...wish I had an exploded view of what it should look like correctly put together--does that large belt need to go back around another wheel or around that metal post that sticks out behind the roller brush?
  • SC1959 May 11, 2010
    Link to exploded parts not working
  • Anonymous Mar 24, 2014
    i need to get my vacuum replace that i bought on 12/21/2013 the brush wont turn both belts are in good shape i think its in between the two wheels
A
Anonymous
Yes, one end goes around the large wheel and the other end goes around the metal post. If the rubber band isn't set around the metal post correctly, it can slide off - and if it doesn't slide off completely it'll continue to turn and burn rubber as it's rotating off the big wheel. It can ruin the band obviously, but they're fairly inexpensive to replace.
Anonymous
Level 3:
  • Master 625 Answers
  • Posted on Sep 15, 2007
Anonymous
Master
Level 3:
Answers
625
Questions
7
Helped
679475
Points
1177
Please go to the hoover vac store using the following link. you will have your exploded diagram for the machine and any spare parts you might need. http://www.thehooverstore.com/U6425.html
Hoover vacuum started smoking
Sounds like the roller became stuck and the motor burnt the belt into. I worked on Hovers for years and that is the most common problem.
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
1helpful
Hoover canister vacuum (windtunnel)- turned it on and it had good suction, then smoke came out and it smells like something is burning. Is it the motor burning up or something else?
Probably the belt..
Turn it over so the bottom is facing up..
Remove the plate that surounds the brush..
Check to se if brush is spinning frely and that the belt is on there poroper
Hoover S3639 Windtunnel Vacuum not on after burning smell
how old is it ?maybe the motor went south.take the cover off and see if you see any burn marks ,maybe you can narrow down the burnig smell.i don't charge people for helping i just enjoy helping.314-628-9153
2helpful
Hoover WIndtunner 7600 no suction
According to the manual on your machine, you can either have a broken belt, or the switches to the self-propel switch, and brush switch are in the off position. I have included a link to your manual. Please look at pages 13-14 under troubleshooting.
http://www.hoover.com/pdfs/manuals/U6439900.pdf
I hope this helps.
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Self propel not working, burning smell
Flip the vacuum cleaner over and check the roller brush. Is it full of string and hair? If so, unscrew the four phillips-head screws holding the plate on that covers the roller brush; pull out the brush, and cut off/clean off all the hair and string. Replace everything and try running the vacuum. Alternate solution: perhaps the belt that makes the brush go around is broken. If so, follow the above steps to remove the roller brush, then replace the belt.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
