Question about Toys
Factory reset of leappad ultra - Toys
    New Friend:
Download and install Leapfrog connect. If it doesn't download, there's an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
Posted on Dec 11, 2013
  • 3 more comments
  • Anonymous Jan 12, 2014
    buy another one
    Add
  • lynnsantana
    lynnsantana Feb 24, 2014
    when factory resting this device does it delete normal apps that come with on the leappad ultra. and my other question is does it reset to set up another parental pass code go away and have to be reset
  • karen daley
    karen daley Feb 19, 2015
    the answer to reset leap pad ultra is awesome , it works
  • karen daley
    yes u have reset another parental code, but wite down the info
If unable to pass the country selection, parent setup screen, or child setup screen while performing the initial setup of the LeapPad Ultra, please perform the following instructions:
Download and install LeapFrog Connect again from www.leapfrog.com/connect
Launch the LeapFrog Connect application.
Power on and connect the LeapPad Ultra.
Let LeapPad Ultra sync until LeapFrog Connect tells you to disconnect and create a player profile.
Disconnect device and proceed with the starter flow on the LeapPad Ultra.
If the above instructions to not resolve the issues, please sync your device with LeapFrog Connect Software while in "Connection Needed" mode. To set a device to "Connection Needed" mode, please click the link for detailed instructions.
http://leapfrog.custhelp.com/app/answers/detail/a_id/2365/kw/firmware
A hard reset can be performed only if the above troubleshooting is not successful .
To do a hard reset
1) Launch LeapFrog Connect
2) On your keyboard, press and hold down Ctrl + Shift + R ( on a Mac "Command + Shift + R").
3) A pop up box will prompt you to connect the device you'd like to reset
4) Power on and connect the toy
Posted on Mar 31, 2014
    New Friend:
Thank you very much the informations helps. Thanksva million
Posted on Feb 19, 2015
SOURCE:
How do i reset the parent passcode on my daughters leappad ultra
If you forgot the parent passcode/lock code you can reset it by following these instructions: Forgot Parent Lock code on LeapPad
Apr 10, 2016 | LeapFrog LeapPad Ultra Learning Tablet -...
How do i reset the 4 digit parent code on my daughter leap frog ultra
Forgot Parent Lock code on LeapPad Published 07/10/2013 01:47 PM ' Updated 06/15/2015 04:11 PM
I forgot my Parent Lock code, how can I access parent settings on the LeapPad3, LeapPad Ultra, or LeapPad Platinum?If you forgot the four digit parent lock code you set up for the LeapPad3, LeapPad Ultra or LeapPad Platinum, you may retrieve the code with these steps:
1. Using a computer or other device connected to the internet, go to www.leapfrog.com
2. Click "Log In/Register" (or "My Account" if already signed in) on the top right of the page.
3. Sign in with the email address used to set up the LeapPad.
4. You'll land on the "My Account" page.
5. Click "Account Information". Directly beneath the orange "Edit" button you will see the Parent Lock code information for any LeapPad3 or LeapPad Ultra set up using this account.
Mar 06, 2015 | LeapFrog LeapPad Ultra Learning Tablet -...
How can I reset my child's leapfrog ultra password
Mar 03, 2015 | LeapFrog LeapPad Ultra Learning Tablet -...
For 4 digit pass code on my leappad ultra
Resetting your leappad ultra isa breeze. First thing you need to do is to download and install Leapfrog connect. If it doesn`t download, there`s an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn`t maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased. Hope it helps
http://youtu.be/dnyle_-2aDYw
Dec 02, 2014 | LeapFrog LeapPad Ultra eBook: DisneyPixar...
IF I WERE TO FACTORY RESET MY LEAPPAD ULTRA WOULD THE PARENTAL CODE BE DELETED WITH IT?
I'm in the same position! I have no idea what to do, did you find a solution? I haven't even been able to Factory Reset because i need the parent code :/
Oct 26, 2014 | LeapFrog LeapPad Ultra Learning Tablet -...
How to reset
Download and install Leapfrog connect. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
Oct 18, 2014 | LeapFrog LeapPad Ultra eBook: DisneyPixar...
Got leap pad ultra but forgot passcode
LeapPad Ultra can be reset by syncing it to the LeapFrog Connect software
OR
Here is a YouTube video with instructions:
Factory Resetting the Leappad 2 - YouTube
http://www.youtube.com/watch?v=dnyle_-2aDY
Jul 16, 2014 | Cell Phones
Bought a leap pad ultra it only has a 4 number passcode and I tried to keep tapping random numbers but it did not work help me
Try this:
OR
I bought my son a leap frog ultra and it already had a code set up on it how do I reset it??? Thanks in advance
OR
May 26, 2014 | Toys
Forgot password to leappad ultra tablet unable to access parent user account
Answers others found helpful
Apr 19, 2014 | LeapFrog LeapPad Ultra Learning Tablet -...
Toys Logo
23,661 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
