We may be able to supply this part for you, and we can certainly assist with the repair. Please feel free to contact us through our Web form on our site. Expert watch repair for Rolex Breitling Tag Heuer Movado
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To
find the daytime or night time on the watch: pull out crown to the
second click and advance watch hands forward till you pass the 12 mark
on dial. If the date changes as you pass it - it is the night time
(midnight). If the date do not change as you pass it - it is the
daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
SOURCE: I need an owner's manual for a Rolex Oyster
2)
NOTE: to
To
daytime (noon).
SOURCE: need a user manual for rolex oyster perpetual date
yes you are right, i believe the mannual repair
SOURCE: Hi, I have a Daytona
Howdy..
Not sure what your question is.. but I assume you wish to know if you have the real thing or not.
The watch you describe is a reproduction and not the genuine article.
I am sure there are other indicators.. however the Daytona and 99.9999% of all Rolex watches do not have engraving on the back cover.
Best of luck
