Sony Cybershot DSC-H3 Digital Camera Logo
Posted on Apr 15, 2009
Sony DSC-H3 memory stick error
Help,
My camara ask me to reinsert the memory, with a C:13:01 error, I have been doing this quite often, but recently even after 20 times, still the same error, could you please help me? it is the camara or the memory, how can a fix this problem.
the memory is 4GB, which work in other camara very well.
Thanks in advance,
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on May 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
546
Points
5
Try inserting your **** on it.... maybe it will work.... and be an error free camara... thnk
2helpful
I have Sony DSC-S40 camera with MS 1Gb, when i switch it on i have "access" then error message says" Memory stick error" and flashing "C:13:01" and I can't take photoes or...
Hello and Welcome to Fixya!
C:13:01 memory stick error message indicates a Self diagnostic message.In C:13:01 the issue may be with the Internal Memory or with the Memory Stick.
To solve it try the following solutions
Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
If it is issue with memory stick then turning the power off and on again or taking out and inserting the "Memory Stick" several times may help in resolving the issue. Error may be because of Unformatted "Memory Stick" which can be resolved by formatting the Memory Stick in the Camera If it not remove by formatting in the camera then connect it to PC and tried to format it again but either FAT instead of FAT32 which is the regular format and then reinserted the memory stick and formatted it with the camara. Now it will be solved if it still exist then it means Memory Stick is broken or not compatible which can be resolved by inserting a new compatible Memory stick
I hope this solution helps you
Your token of appreciation in the form of four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
2helpful
2answers
When I switch it on, I get this error: Memory Stick error C 13:01 camera Sony cyber shot DSC-P73
I hope it will help you
Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
8helpful
2answers
C:13:02
After having formatted the memory stick with the cardreader on my laptop which runs on winxp I tried to use the stick in my sony dsc-p5 but all I got was the C:13:01 error message. So I tried to format it again but eith FAT instead of FAT32 which is the regular format on winxp. Now the disc adapter which I use on my desctop to read the memory sticks worked again with the stickt, my camara still gave me the message of not being able to read the stick so I removed the stick, got into the setup mode, reinserted the stick and formatted it with the camara. This worked, I hope this can help you.
1helpful
2answers
How do i resolve the C:13:01 error on a SONY DSC-W150, "error formatting memory stick" appears on the screen"?
how do you formate memory stick if the camera woke work at all. It keeps saying reinsert memory stick . Must be a w150 problem cause that's what mine is doing too! :(
My sony keeps saying Reinsert the memory stick?
The error message "Reinsert Memory Stick" may occur due to the following reasons:
1. The inserted Memory Stick media is not supported for use with the Camera.
=Ensure you are using the supported type and capacity of Memory Stick media for use with the Camera.
Please click on the below link to check for the compatible Memory Sticks with the Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12
2. The terminals on the Memory Stick media are dirty.
=Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up.
3. The Memory Stick media is damaged.
=Use different Memory Stick media and check if the issue persists.
Reinsert memory stick --- I have removed battery and memory stick with no result. Help
Sony says:
Article ID : 101488 (modified 10/29/2009 03:18:00) Question: A warning message appears on the LCD screen when a Memory Stick is inserted into the camera. Answer: The following could be possible causes for the error message to appear:
  1. Verify that the Memory Stick is inserted correctly.
  2. The inserted Memory Stick cannot be used in the camera. Refer to the related link below for compatible Memory Stick.
  3. The Memory Stick is damaged.
  4. The terminal section of the Memory Stick is dirty.
http://www.sony.com.ph/support/faq/101488/product/dsc-w190/modelfirst
1helpful
My camara is sony cybershot dsc-s930. i am getting error formating memory stick what to do
TO egg-cool-bo
my digital camera when turned on it is coming that
formating error in memory stick.
what should i do?
please help me
2answers
Says to reinsert memory card & card is in camera. Try another card & says memory stick formatting error
i have the same problem..
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Memory Stick error c:13:01 My old 512 MB memory stick is working fine. However, recently I brought a 2 GB memory stick and when I put it inside, the camera (Sony DSC S40 cyber shot) shows: MEMORY STICK...
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
SONY DSC-H3 Memory card file erro
Have you formatted the card in the camera ?
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
