Acer NSK8458AN Keyboard Logo
Posted on Apr 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Right arrow key permanently 'pressed' down
About a month ago I spilt a little bit of milk in my Acer Aspire 5520 keyboard and having poured out the 10ml of milk I thought that would be the end of it. A couple of days later the right arrow key started to press itself randomly, and upon trying to fix that problem the arrow key then stopped working altogether. I now use a USB keyboard, which is fine. Then the right arrow key an hour or two ago (after two weeks of not working at all) started being permanently pressed down again, and I (foolishly) tried to break it permanently by scraping the sensor with nail scissors. It's still 'pressed down' and as you can imagine, is driving me crazy when going about everyday computery things.
My question is more simple than that ramble above... how do you disable the main laptop keyboard, and substitute the USB keyboard in its place? I'm sure there should be a way to do this, as I doubt noone else has ever 'milked' their laptop! I have Windows Vista, and was told to go into 'device manager', but every time I click on a device I'm not really able to alter it as such... it just tells me 'this device is working properly'. :( Please help someone!
Anonymous
Level 2:
Scholar:
  • Expert 150 Answers
  • Posted on Apr 17, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
150
Questions
Helped
48441
Points
421
Only solution here is to unplug the keyboard from the mother board. Just take apart the case and look for the ribbon cable going from the keyboard to the motherboard, and take it out.
Please rate, thanks!
Acer laptop stuck on Windows boot manager
1. Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time.
2. During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup."
3. Keep pressing the "F8" key until the "Advanced Boot Options" menu appears.
If you receive a "keyboard error," restart the Acer Aspire and repeat step 2.
4. Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu.
The arrow keys are located on the right-hand side of the Acer Aspire keyboard.
5. Press the "Enter" key to execute the "Safe Mode" selection.
The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again.
How do I get into safemode on my acer aspire desktop
1 Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time. 2 During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup." 3 Keep pressing the "F8" key until the "Advanced Boot Options" menu appears. If you receive a "keyboard error," restart the Acer Aspire and repeat step 2. 4 Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu. The arrow keys are located on the right-hand side of the Acer Aspire keyboard. 5 Press the "Enter" key to execute the "Safe Mode" selection. The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again. Read more: How to Boot Up Acer Aspire in Safe Mode ' eHow.com http://www.ehow.com/how_5802430_boot-acer-aspire-safe-mode.html#ixzz1dtOxfxaD
How do Iget the question mark symbol from the keyboard key to activate I need the right side function on the keyAspire 5552-7686
Hi
if you are using an english keyboard then if you hold down the shift key and press the ? key then you should get the ?
many thanks
Factory reset without using a disk and ALT + F10 doesnt work
his MIGHT work:
1. Click "Start," "Turn Off Computer" and then "Restart", if it is on. If your computer is off, turn it on by pressing the power button above the keyboard.
2. Press the "F2" function key on your computer's keyboard to enter the BIOS utility.
3. Use the laptop's right arrow key to scroll to "Main." Confirm that the "D2D Recovery" is "Enabled." If the D2D option is "Disabled," scroll down to the option using the down arrow key. Press "Enter" to change the option to "Enabled."
4. Use the laptop's right arrow key to scroll to "Exit." The "Exit Saving Changes" option will be highlighted. Press "Enter" to save the settings and exit the BIOS utility. Your Acer Aspire will restart.
Reformatting the Acer Aspire
1. Press the "ALT" and "F10" keys together while your computer is restarting and the Acer logo is showing to enter the Acer Aspire's reformatting utility.
2. Follow the on-screen prompts. Your laptop's hard drive will reformat and the original applications will be reinstalled. Your computer will restart after the reformatting process is complete.
3. Enter your name and other personal information when prompted during the Windows operating system setup process.
2answers
Tomato sauce spilt on acer netbook keyboard.some keys really sticking down.sauce gone under some keys.
It would be better if you call the Acer technical support no and get it repaired before your mainboard gets fried.
1helpful
I cant locate fn key on acer aspire one to raise
Fn key is bottom left of keyboard, volume keys (up and down arrows) are bottom right.
I have an acer notebook. model aspire 5520. what
Simply press the WiFi on/off key (it's the first key from left to right, between the "Power" button and the laptop's keyboard). A message should appear on the screen telling about the WiFi adpter's state (on or off).
Glad if I could help!
2answers
Acer 5520-5142 ?????
Try to re-install Microsoft Office... and then see...
I spilt my drink on my laptop keyboard...
you can pull the keys out of their sockets and wipe the rubber and plastic holders with a wet cloth. but be very carefull to cloth should not leak, just be wet to dissolve and absorbe the sugar and other stuff that stick the keys. then just insert the keys in the sockets
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
