SOURCE: power indication light flashing
Hi, you may want to try connecting it by USB if you're currently using firewire or the other way around and see if it works. If this fails, you are probably better off using diagnostics by Seagate @ http://www.seagate.com/ww/v/index.jsp?vgnextoid=7f4e19e0babfd010VgnVCM100000dd04090aRCRD&locale=en-US#. Try to use the Troubleshooting or FAQ or if you feel comfortable using their utilities, download SeaTools. Hope this be of help to you. Good luck.
SOURCE: Seagate Free Agent Desktop Drive Not Recognized
I took my enclosure apart completely (not recommended since it was difficult breaking the snapping points), and I hooked up the drive just like an internal HDD. The BIOS was able to detect the drive so nothing is wrong with the drive itself.
I've also read that the controller on some of the FreeAgent drives fail. Mine started making buzzing sounds and finally failed. So you can take the drive out and put it in your computer, get a new enclosure, or send it back to Seagate where they should replace it.
SOURCE: seagate external hard drive problem
I have the same problem with a 500GB HD by the same maker. Fortunately mine started throwing "delayed write failed" errors regarding the MFT. I had enough time to save my data. Your event log should say something to point you in the right direction. Make sure your pc is up to date with the latest service pack too and start looking for a new External HD. Tiger Direct has great deals. I got a 1TB for about $120 Good Luck!
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
SOURCE: When I plug my Seagate GoFlex 500 GB external hard
Hello
Your hard drive is defective. This is very common on external USB hard drives. Your options here are to have a data recovery service retrieve the stored information off the disk of the drive or just replace it if the information is not vital and the drive is not the only place you had it stored. Data recovery services are on the Internet, just Goggle it, it is however fairly expensive. These drives are not repairable due to the extremely precise way they are manufactured..
