Sonostar Sonocaddie V100 Handheld GPS Receiver Logo
A
Anonymous Posted on Sep 12, 2013
Replacement battery Sonocaddie V100 - Sonostar Sonocaddie V100 Handheld GPS Receiver
1 Related Answer
pokey967
  • 7 Answers
  • Posted on May 30, 2010
SOURCE: Sonocaddie v100 won't turn on....
Looking directly at the unit from the front, hold the left side button down for several seconds. The unit will turn on and if not, then the unit is defective.
I cannot reach sonocaddie software on my acer chromebook
Make sure your software and drivers are up to date.
https://sonocaddie-v100.software.informer.com/
Manual
Install The Software And Login - Sonocaddie V300 User ...
https://www.manualslib.com > ... > V300 > User manual
Sonocaddie V300 Manual Online: Install The Sonocaddie V300 Software And Login. Step1. Insert the supplied Installation Disc into your computer. When the .
1helpful
The sonnocaddie does not keep power for longer than 20min after being fully charged. Can the battery be replaced?
That depends on the model you have if it is not a discontinued model you may find one try looking at this link:
http://www.sonocaddie.com/#Menu=ChildMenu6
Sonocaddie xv2
Amazon have them.
http://www.amazon.com/Classic-Straight-Sonocaddie-Charge-Capabilities/dp/B004AQJAKG/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1399922759&sr=1-1-catcorr&keywords=Sonocaddie+cable
2answers
Need replacement usb cable for sonocaddie xv2
It can be bought from most of the electronic spare part selling shops. Gopakumar Gopalan Google
My synocaddie V100 does not hold a charge anymore,it works when connected to computer or electric a supply, when disconnect battery only lasts about 10 min. Manual says battery cannot be removed.
Some batteries cannot be replaced which means that the device has outlived its usefulness. Bear in mind that all electronic devices come with a life span and unfortunately unless you take it back to Sonocaddie and they can do something for you its probably time to look at getting a new one.
2answers
Hi there - trying to downlaod courses on Sonocaddie V100 - have downloaded software and drivers - restarted - when starting the programme Windows 7 asks for permission - click ok then get message saying...
Hi harry953,
Please follow these download procedure:
1. Download Sonocaddie "V100 USB Cable Driver". Click here.
2. Download Sonocaddie "V100 Software". Click here.
This application software allows you to download course data and mange your V100 personalized course folder. Please refer the "Instruction" to know how to install and operate this application software.
3. Download Course Data. Click here.
NOTE: V100 Software and membership are required to download course data.
For the user guide. please visit this link.
Hope it helps.
Thank you for using FixYa.
Top Sonostar GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Sonostar GPS Expert? Answer questions, earn points and help others
