Turn off the other channel and listen only to the bad channel playing some music. Turn it up! If you hear any music the pre-amp is working and the power amp is faulty. If you don't, then the pre-amp is faulty.
Because it's a stereo amp you have the good channel to compare with the bad. So you can do voltage tests, or "buzz" tests. Buzz Tests or where you apply a insulated tool to the circuits, a buzz will be heard. If it buzzers in the good channel it should in the bad. Ignore the power supply and don't short any parts out!
