Garden Logo
A
Anonymous Posted on Sep 11, 2013
Need a repair breakdown on ridgid 3000 suburu engine
protojexxx
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Sep 16, 2014
protojexxx
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
20811
Points
115
Go here and get the manual. Inside you'll find links for your engine and the numbers you'll need to get the literature.
https://www.ridgid.com/us/en/literature-search
How do I fix an idle issue with my Ridgid 3000 psi pressure washer?
Run some carburetor cleaner through it first. Go to autozone, etc, and pick up some fuel system cleaner you can put directly in the tank and run it through.
What causes funny idle with a rigid 3000 psi pressure washer
Get some fuel system cleaner you can put directly into gas tank from autozone, etc, parts store and run it through before you do anything else.
What spark plug
Go here and input your model number to search for your manual. The number is in there.
How to adjust unloader valve for RD80701
Screw unloader valve out. Turn to left or till it quits killing the motor.
Nov 29, 2013 • Garden
1helpful
2answers
18volt cordless drill with switch problem
Howdy, Ridgid toolos has a decent repair network in the US and some other areas. I have included a link to their service finder with this reply:
http://www.ridgid.com/Tools/Technical-Services/index.htm
The prime vendor of Ridgid tools is Home Depot, but they are little help unless you are still within the return window.
I know some hardware service centers will work on various brands, but it may void the warranty.
I hope this helps a bit.
Regards, Farmerbear
MY RIDGID ROOFING GUN will not feed the nails and then jams up because it trys to shoot two nails how can i fix it?
I would look at the deeder area which is close to the plunger. If not properly oiled, it will jam up like this. See the link below and enter the model number (R175RND) to get the complete parts breakdown diagram. That should help you to open up the unit and check it out. Also examine any O-rings for signs of wear.
Dan
Link: http://www.ereplacementparts.com/ridgid-parts-c-7929.html?gclid=CJLzi4D70aMCFQo65QodJDG7wQ
2answers
The gun will fire but the plunger will not retract back up into the chamber.
This unit likely needs oiling +/or O-rings. See the link below and enter your model number to get a complete parts breakdown diagram. Focus on the o-rings for the main plunger assembly.
Dan
Link: http://www.ereplacementparts.com/ridgid-parts-c-7929.html?gclid=CJj0yNXm0qMCFZxo5Qod9QMmug
Top Ridgid Garden Experts
Jay Finke
Jay Finke
john h
Are you a Ridgid Garden Expert? Answer questions, earn points and help others
