This does not fix my tv
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) Hope this helps you!
Thank you for your help. This information halp me solver my problem. Thanks
I got the code. Vertical problem, I replaced the vertical IC still some, then I did tests on vartical circuit eventhing was fine, the I checked the signal board, it had problem, the I replaced the signal board now the tv is working fine. Thank you help
