SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
SOURCE: cub cadet starts but won't move forward or reverse
What model? I have a 1554, that I just took to the dealer, for repairs, for the same thing. The motor starts, the blades engage and cut, it just stopped moving forward, or reverse. If I remember, I'll get back on here and let you know, unless you already know?
SOURCE: Cub Cadet HYdro, LTX1045 goes in
My name is Todd and I will try to help you fix this problem.
Are the blades engaged in this condition or does it not matter whether the blade is engaged? Is the reverse caution mode key position engaged? Is the reverse pedal feel different, as though it is push down to the bottom? reach behind the forward pedal check the cable from the pad. See if the cable is broken. Let me know your findings.
SOURCE: my cub cadet 1110 transmission goes backwards when
some one work on the linkage and but it back wrong?
