1. These instructions from Microsoft will explain how to run a compatibility troubleshooter for your software.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
2. Contact Broderbund directly at 800-395-0277. I use their Print Master software also and they are very helpful at the customer service area.
I have Installed and run 'PrintMaster Premiere 7.0' on my Win 7 Pro 64 bit computer,using XP Mode. It should also work for version 8.0 as well
Try installing the software using the 'Windows Virtual PC Win XP mode', that comes bundled with Win7 Pro and above.
Look for it in the Start menu taskbar button, in the 'Windows Virtual PC' folder.
If you have Windows 7 Home premium or less it won't be installed and you will have to download them
from Microsoft..
step 1. Download and install Windows Virtual PC at;
http://www.microsoft.com/en-CA/download/details.aspx?id=3
step 2. Download and install Windows XP mode at;
http://www.microsoft.com/en-us/download/details.aspx?id=3702
Step 3. Then run XP Mode from the Startmenu All programs, Windows Virtual PC folder.
Step 4. Install your 'Printmaster 8.0' discs and it should work.. good luck :)
SOURCE: just purchased a new computer running Windows 7
to: Brettdixon16...............Why in heck would I buy a new Mac after just spending almost two grand on a new P.C.???? Thanks for nothing
SOURCE: Hi, I have used printmaster
the problem is that windows 7 is not compatible with Print-Master premier 7.0
The program cannot run on windows 7 because it wasn't programmed for it. This is why the error message comes up.
There is nothing you or anyone can do about this.
Sorry about this.
Regards.
Try installing PrintMaster Deluxe 7.0 on Vista, using the compatibility mode to windows 98.
Hope it helps.
