Acer AT4220B 42 in. LCD TV Logo
Noel Keville Posted on Oct 09, 2017
My daughter's bush LCD19880HDP screen has gone pale & washed out. However the HDMI Connection is perfect when I connect my laptop to it, but the built in DTV (freeview) & DVD via scart connection are just pale & washed out too. The tuning / installation part of the menu is also pale but the main menu where you adjust the brightness & sound is fine.
4 Related Answers
Anonymous
  • 563 Answers
  • Posted on Mar 27, 2008
SOURCE: Acer PD726W
Hi there
You'll have to settle for the ordinary Composite input on the Projector.
You do get a scart to composite convertor from most good PC & AV shops.
Theknack
Technocom
  • 144 Answers
  • Posted on Apr 27, 2008
SOURCE: Laptop HDMI fuctionality
Normally the sound should come out also.Have you tested that CD to make sure that it has sound??? Try some other program to play the CD like DVDplayer or some other player program to see because they have more option to set for sound output.
takecare.
Anonymous
  • 10 Answers
  • Posted on May 29, 2009
SOURCE: no sound on tv when laptop connected via hdmi
if you are running windows xp or linus i may not be able to help altought the problem might be solved in almoust the same way. For windows vista right click on the volume icon in the system tray icons and choose playback devices select HDMI output ( for 5920G is "Realtek HDMI Output" ) then press the "Set Default" button. The other way around is to go in the Control Pannel in the "Hardware and sound" cthegory and select sount than seth the default output to Realtek HDMI Output in the "Control Pannel Home" view, or in Classic view click/doubble click on "Sound" icon ( a speaker ) and do the same. In windows XP there is a similar approach. In linux go to System ->> Administration ->> Soundcard Detection and you should find a setting equivalent to the one in Windows
Anonymous
  • 262 Answers
  • Posted on Nov 06, 2009
SOURCE: Blu Ray not playing when HDMI connected
sure you have blue ray?
My monitor was working perfectly fine until I unplugged it to play on ps3 so when i did the ps3 wouldnt connect i tried holding down the ps3 button nothing so i plugged back into laptop no connection.
Have you used the HDMI cable with the PS3 before? it may be configured to use the AV connection. If so plug in an AV lead, then you would need to find in the settings to change the output to HDMI.
The HDMI cable may not work
Press windows key and P to switch between monitor modes
Try those and post back if you need more help.
No Sound on LG Super Blu-Ray Disc & HD DVD
Its something wrong in the cables connection try to reconnect them! And make sure that the connection is perfect according to manual then try it. It should work nicely. Moreove HDMI has great sound + picture effect.
I have been using my panasonic tv as a display to watch films on from my laptop via HDMI however now i am just getting a black screen. the TV recognises that the laptop is connected and so does the la
try holding the hdmi wire connecting to the tv port at a slight angle, if it comes on then the hdmi connection is damaged,do you have sound?
give the connection a wiggle and inspect the connection, maybe worth a reset?
Connecting VGA Screen to HDMI laptop
Press and Hold "Fn" and then press number key with "square / square w/ legs (like monitor)" icons
If you need further help, reach me via phone at https://www.6ya.com/expert/hee_458d01a29d21e0d3
Connection vga for bush led tv
Clarify your question? Are you going from your VGA out on your notebook and you want it to be plugged in to the HDMI input?
you should have a vga input on your led TV. if you still want it to run on HDMI, then you need an adapter from VGA male to HDMI, you can find it on amazon.comTony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
1helpful
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
2answers
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Replaced cartridges
keep cleaning untill it starts to print clearly, you may reuse the same paper for that purpose, if you don't see any progress after 10 cleans, consider getting lasser printers, they are immune to print head drying and save alot of money on ink replacements. go with brother color or black and white series. I switched and don't have problems anymore
1helpful
Replaced cartridges
Hi there :
on mine i had to use some rubbing alcohol and clean the new cartridge and the contact area on the p[rinter then reinstalled the cartridges and kept running the cleaner program and then about 15 sheets of paper later it finally cleared up and the color returned to normal and i had no more prohblems
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Top Acer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
